Sky InsuranceBadger5
Results 1 to 7 of 7
    Sep 2007
    Larger wheels at last (I hope)
    Hi guys, a quick wheel question from someone with not a lot of experience in this area. I'm thinking of changing my embarrassing 195/65R15 wheels to a set of RS6's with 225/40R18's on them. I am aware that there will be a slight difference in the rolling circumferences and was wondering to what extent this will effect speedo readings???? I presume there a way to programme in the new tire size so as to keep the speed reading true???
    Carpy25's Avatar
    Oct 2007
    272
    check here , it says that it will be ok
    http://www.rtecalloywheels.co.uk/fitment_guide.htm
    Rob
    Nov 2006
    liverpool
    703
    doesnt make any difference- well not tha i noticed anyway and i went from 15' to 19s
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    It stays the same, what you go up in size on the alloys you go down on the wall / profile of the tyre.
    LOTS DONE, LOTS SPENT !!!!
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    if you put the 15's next to the 18's with the tyres fitted you will notice that they will be quite a bit bigger but it shouldn't affect the speedo by much. when i upgraded mine from 15" to 18" it knocked the speedo out by about 4mph
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    I went from 15's to 18's to 19's and my speedo got more accurate compared to my sat nav.
    Sep 2007
    cheers guys been very helpfull
