EM TuningMonster Motorsport
Results 1 to 9 of 9
    gaz j's Avatar
    Jan 2007
    Cheshire
    137
    Where's the fuel filter?
    Where is the fuel filter on a 1.8T (190)? And are they easy to replace? If yes, how much are they and where do you get them from? (apart from stealers). Thanks for any help.
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    i think its in the boot but i'm probably wrong, come to think of it, thats probably the fuel pump!!! anyhoo, i would imagine you could get a new filter from gsf
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    bubstar's Avatar
    Jul 2004
    Surrey
    546
    No filter as such, it's in the fuel tank with the pump.
    Not a serviceable item.
    BUB :spanner:
    A4 Avant S-Line quattro - Avus Silver/Silver Half Leather *240ps*346nm* - a few choice mods. Now Stared up ;-)
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    The fuel filter you're referring to is found under the car by the fuel tank. It is usually hidden away under protective trim, but the trim can be removed easily enough.
    The fuel filters are around £30, because they work in a different way to regular filters. It is an easy enough job, but is rather fiddly and can be dangerous as fuel is involved.
    It took me all of 15 mins to do it on my 1.8T, but it did have some annoying clips that hold the filter in place which wouldn't budge. If you do do it yourself, make sure you open the fuel filler cap to release all the pressure and that you wear gloves and have a cloth ready to mop up any spilt fuel.
    Apr 2006
    Yorks
    111
    Eye protection would be a good idea too.
    gaz j's Avatar
    Jan 2007
    Cheshire
    137
    Thanks for help, where can i buy these from? My local motor factors don't stock them, so do i have to go audi?
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    Quote Originally Posted by gaz j
    have you tried gsf like i said in my first post?
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Audi are the only people who stock the filter. GSF and EuroCarparts didn't have the filter when I enquired. Also, it is a special order item, so it will have to be ordered in, and cannot be returned.
    Mar 2007
    184
    hello matey
    is this what your after?
