Monster MotorsportChris Nott
    Feb 2007
    40
    charge pressure control?
    bit worried.... got a vag check today after getting fed up of an annoying whirring noise coming from engine after 40 miles ph...had assumed it was cause i changed my tyres....
    fault code 17964 charge pressure control - negative deviation p1556 35 00
    SHOULD I BE WORRIED???
    HELP PLEASE!!!!
    Feb 2007
    40
    please help me out here guys.... someone must know what charge pressure is????
    steve
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    nothing worry about,check all you hoses for any splits. Also check your n75 valve.Boost Pressure too Low
    Hoses/Pipes incorrect connected, disconnected or leaking
    Charger Pressure Control defective
    • VNT (variable nozzle turbo): nozzles stuck
    Solenoid Valve for Boost Pressure Control (N75) defective
