Volks AutosSky Insurance
Results 1 to 8 of 8
    M22_PRE's Avatar
    A4 autovogue style
    Sep 2007
    North West
    124
    Are these sidelight bulbs the ones i need to match a h.i.d kit???
    found these i have an 03 reg tdi think these are the correct fitment or does anyone have any other suggestions
    link
    http://www.aceparts.com/all-led-bulb...-sidelight.htm
    Nov 2006
    liverpool
    703
    allow me to be the first to tell you that LEDs wont work, i think they keep blowing or cause some sorta dash error.
    Jan 2007
    Hampshire
    1,155
    You will need to wire a resistor in when you fit LED's, otherwise the DIS will constantly show the 'bulb-out' warning.
    A6 3.0 TDI.
    Oct 2007
    69
    where do you get these resistors from?? and how do you go about wiring them in??
    3.0 V6 Quattro Sport.
    technics100's Avatar
    Feb 2004
    Co Antrim
    771
    I never liked the LED side lights when fitted, I tried 2 sets before changing back to white normal bulbs..
    The light from the LED is too direct and doesn't reflect around the light housing, just means you see the bulb itself and not the light housing lighting up..
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    M22_PRE's Avatar
    A4 autovogue style
    Sep 2007
    North West
    124
    oh rite ok. wat wud u advise then as at the mo my sidelights are kind of yellow and dipped beam is white/blue
    A4 TC's Avatar
    1.8T quattro sline
    Nov 2006
    Toon Toon
    194
    Quote Originally Posted by technics100
    You actually got them to work? . the ones i tried just flashed all the time, there was a thread about this a while back how a resistor was meant to help, dont know how or who has done this yet.
    Oct 2007
    69
    same thing happened to me the leds would just flash on an off
