JMB RetrofitsVolks Autos
    Aug 2006
    NI
    785
    A4 brake problem - brakes stuck on
    hope you can help, my A4 (130tdi) has gone all christine on me. on the way to work this morning (0deg C if that makes a diff) the brakes had a wobbly fit.
    started off just being a little heavy on the braking, was like Id pressed the brake pedal harder than I actually had.
    then when I braked the pedal stayed depressed for a couple of seconds extra. as if Id kept my foot on the brake.
    gradually it got worse and the brakes were constantly binding, the abs light and the triangle with a circle round light came on.
    when I made it home both front calipers were smoking.
    any ideas? car is out of action until I can get it sorted
    thanks all
    back to boost, oh how I missed thee....
    Nickynibbles's Avatar
    Damn it where's 7th gear when you need it?!
    Jun 2007
    Hampshire
    846
    Could be the switch on your brake pedal has gone and so the calipers are not releasing properly. I've heard of various pedal switches going before and not meant to be an expensive or tricky fix.
    A4 3.0 Quattro Sport - Gone & missed everyday!
    Current road going missile.....
    ........Smart Roadster - arguably the most fun you can have in a car without using lube!!
    Aug 2006
    NI
    785
    thanks for the reply
    what does the switch do?
    Dec 2006
    N.Ireland
    369
    pabs.. the switch is for the brake lights
