Chris NottBadger5
Page 2 of 2 FirstFirst 12
Results 41 to 64 of 64
Like Tree2Likes
Thread: HELP! windscreen demister
  1. #41
    LandSpeed's Avatar
    Nov 2006
    Birmingham
    226
    Ive also just had the same problem, thatnks to all of the above for descritions and photo's, just re-installed my glove box and its working fine at the moment !
    If you have a CD Autochanger located in the glove box you will also have to remove that before you are able to remove the glovebox as there is another bolt scerew that sits abouve the changer on the top row so there is infacet 6 bolt screws (4 along the top and two at the bottom of the glovebox
    1.8t Multitronic 2002
    RNS-E - Xenons - Full Leather - Cruise - DIS - Interior Light Pack - Ambient Lighting - RS4 ARB - 19" Hartman MTM Reps
    Ready to be installed: S Line front spoiler - S4 Rear Bumper - Eibach Sportline Springs
  3. #42
    Jan 2011
    I've just joined this forum but looked at it yesterday as demister stopped working, following all the advise, I took the glove box out today and appears that the servo has crashed. I'll get one ordered and put back, hopefully this will do it. Great stuff, thanks for the advise. My 52 plate A4 1.9 has now clocked up 211,000 so feel I owe it a bit of TLC! Am going to put some of the broken bits back together, first off, the ash tray lid won't stay closed? Any ideas?
    Thanks again for the servo advise.
  4. #43
    Gavlar's Avatar
    Sep 2010
    Maidstone, Kent
    312
    Would this be the same for the heating as when my passenger side is set on cold it just comes out hot. Anyone have any idea what this could be?
  5. #44
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    Quote Originally Posted by Gavlar View Post
    did you get this sorted mate? i wouldn't imagine this would affect hot/cold as it's just the direction of air. But possibly one of the other servos and linkages is responsible for closing/opening the flow of hot air from the heater matrix.
    Quick Question to the people who have done this - Is there a servo each side that controls the left and right side of the screen?
    Anybody selling a polisher? PM me.
    A4 B6 3.0 Quattro Sport Avant
  6. #45
    Oct 2012
    79
    My screen demist (Centre Vent) and both dashtop side vents are today feeling breathless.
    Does the green armateur servo drive the flap for all 3 vents dashtop/screen vents or is there another/sperate servos for centre and side demist.
    What servo's are one the pedal side ?? for what vents ?
    Face vent works fine as does the floor vent, but when I switch to top/screen vent no air comes out but you do get some floor heating.
    When on the centre vent setting the floor heating closes off as expected. Revert back to screen and face vent goes off as expected, but floor opens again ?
  7. #46
    Oct 2009
    Hull
    1,437
    the one with the green arms is for the centre vent only I'm not sure what the others are
    When my centre vent went I just unscrewed the servo and pulled it down so it was open all the time! and from the advice of another member I opened the servo and cleaned it up and greased it put it back on then reset all the flaps with VCDS and all has been well since
    I also had a potentiometer fault flag up on VCDS on one of them so I opened it up sprayed it with wd40 greased it all and its been fine since!
  8. #47
    42
    As stu-m says, it is possible to open up the little servo gearbox. There was a photo sequence of this on this forum last year, which I can't now find, which is very irritating as mine's just started doing it again occassionally. It seems as if the 2003 grease is starting to dry out now and everyone is getting this problem at about the same age - particularly in cold weather, tighter plastic and lower battery volts.
  9. #48
    Oct 2009
    Hull
    1,437
    you dont need the pics to open them they are so easy
    I did mine in about 5 mins there is little clips on the side use a small flat blade screw driver and work your way round carefully
  10. #49
    Oct 2012
    Stanley, County Durham
    151
    What do you do once you have it open? Removed mine a few weeks ago but never got round to opening the thing up! Any how-to guides anywhere?
  11. #50
    Oct 2009
    Hull
    1,437
    there is a how too guide somewhere
    open it up remove all the parts clean then grease them and re assemble simple
  12. #51
    V6 Quatt's Avatar
    Feb 2008
    776
    As one member said, drop glove box and open stuck vent until you replace motor. Did it on my last B7 and it was fineto leave open as my main concern was to desist the print Windows
    Torque the Torque
  13. #52
    Jul 2010
    217
    Is the glovebox removal any different for a glovebox with cool box? I'm guessing I'll have to disconnect the aircon hoses but any hiden screws behind the cool box?
  14. #53
    Z82
    Apr 2006
    Inverness, Scotland.
    453
    Sorry cant help you there Paul.
    Thanks to others as this helped me fix mine on my 2003 S4. Once i got the motor off and manualy moved it it started to work again, the glove box will stay on the floor till im satisfied its fully functional after reading that a few of you had to remove it several times lol
    7. 2003 B6 Nogaro Blue S4 v8 quattro
    Gone but not forgotten:
    6. 1996 B5 Casablanca White A4 2.6 v6 quattro Sport
    5. 1989 B3 Maroon Coupe 2.0E
    4. 1986 B2 Red Coupe 2.2E Limited Edition
    3. 1985 B2 Red 80 Sport
    2. 1983 B2 Black 80 Sport
    1. 1984 B2 Silver 80 Sport
  15. #54
    Jul 2010
    217
    Well, I had the glove box out to fix the hinge and for future reference for anyone it's best you unscrew the fitting from the inside of the cool box first, when I removed my glovebox the pipe pulled out of the aircon unit, but it just twists back in there.
    I took my actuator apart, removed the motor span the gears, lubed it a bit more, then plugged it back in and seemed to working fine. So time will tell but glove box is back in!
  16. #55
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,568
    Thankfully the car I've bought had all this work done in 2011 so no removing the cool box/glovebox for me!! Happy days lol
    2002 2.5 V6 Quattro
  17. #56
    Quattrodude's Avatar
    Jan 2014
    Manchester
    41
    Hi, I bought my car on Saturday and this morning, which was a cold one, I had difficulty clearing the front screen. It seemed ok if I ran the blowers using only the arrow up button on the climate unit, however when I pressed the clear windscreen button, the fans seemed to engage into a different setting judging by the sound that was made, but the screen seemed to steam up really badly.
    I reactivated the arrow up button which should also direct air to the window and it seemed to take an age to clear, which it did eventually. It also struggled if I had the cabin vents activated. I resorted to also opening the windows slightly as the whole car steamed up.
    Does this sound like a similar problem, or possibly pollen filter?
    Chris
    A4 2.0T Avant S-Line Quattro, room in the boot for a leisurely lifestyle
  18. #57
    Jimmy TDI's Avatar
    Pro Tinkerer
    Dec 2013
    Manchester
    374
    If you put the screen only on you should be able to feel air coming from the dash bent, if not then the motor might not be working correctly.
    As you say the pollen filter could need changing, and also the inside of the windows might need cleaning, you will be surprised how much more they steam up when they're dirty.
    Made on the red side of Manchester
  19. #58
    Jan 2014
    Manchester
    41
    Hi, yeah good point, the screen probably does need a clean as the areas where the stickers were when it was on the forecourt are the only places that stay clean. I'll check the pollen filter too.
  20. #59
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Does your AC work properly? Sometimes they steam up badly without it.
  21. #60
    Jan 2014
    Manchester
    41
    yeah it seems cold enough
  22. #61
    Jan 2014
    Long time reader - first time poster. Great forum!
    I've had an intermittent issue with the screen demister on my A4 so followed your advice here, took out the glove box, unscrewed the servomotor connected to the green arm, jigged it around a bit and it worked for two weeks. Happy days!
    Anyhow, this morning , it's causing me grief and after loosening it again, it looks like it isn't really moving at all. (I think!)
    What's the behaviour of these things when they are on the way out? Might it work for a week and give up totally? Is the servomotor attached to the green arm dependent on the others in some way?
    The bit I really am scratching my head about!!! ..... How do I get the one attached to the green arm out? How do I disconnect the servomotor from the green arm?
  23. #62
    Oct 2013
    178
    I've just had my motor out and apart this evening! It only played up once but I wanted to save it from dying permanently. I greased the cogs with thick motor grease and then used silicone spray on all of the coloured moving arms. Hopefully this will extend the life of these bits.
    To get the motor off of the green arm you need to remove the two small screws and then rotate the motor until the green bits slide apart.
  24. #63
    Jan 2014
    Quote Originally Posted by MooLard View Post
    Thanks for that MooLard.
    So, the green arms will stay attached and I'll just have the motor. It's the two small screws keeping the motor in place?
    Not even sure if the motor is still moving. It was a couple of weeks ago. It seems to be in a middle position at the moment meaning a clear windscreen but colder feet than normal! Cheers.
  25. #64
    Oct 2013
    178
    It's this time of the year when lots of posts about this problem seem to appear, just after Christmas spending, and at the colder end of the year!
    Yes one small piece of green plastic remains attached to the black motor box but the rest of the green linkage stays there.
    Once it's off move the linkage with your hand to see if it moves freely. You could potentially put voltage on the motor to test but I don't know what voltage is safe, so it's probably better to refurb and connect back up and try it with the glovebox still off and out of the way.
