JMB RetrofitsChris Nott
Results 1 to 10 of 10
    goodhixy's Avatar
    Nov 2007
    14
    A4 Cabriolet - Window rattle..help...
    Happy new year guys - I have a 54 A4 Cabriolet with an annoying rattle from the top of the passenger front window...when the window is fully up I get a very loud rattle..when I put it down by a few mm it stops...I can't see anything obvious...any ideas??
    Nickynibbles's Avatar
    Damn it where's 7th gear when you need it?!
    Jun 2007
    Hampshire
    846
    Is the rattle from the top of the window or from inside the door itself? Its probably one of the guides or supports for the window pane giving you the problem, you'll just need to sit in the passenger seat and narrow down the sound location itself. The cabs windows get more use than normal because they have to drop a little every time you open the door, not unlikely to have something wear a little. Are you just about in warranty still though?
    A4 3.0 Quattro Sport - Gone & missed everyday!
    Current road going missile.....
    ........Smart Roadster - arguably the most fun you can have in a car without using lube!!
    goodhixy's Avatar
    Nov 2007
    14
    Thanks for the reply - it's at the top of the window 'frame'
    Jun 2007
    Hampshire
    846
    Have a look at where the window nestles into the roof, there will no doubt be something that is a little loose giving you the rattle. Also, compare the drivers side to passenger side in case a travel guide has fallen out again causing the rattle.
    andyccr's Avatar
    2003 1.8T Sport Ebony Black A4 Cabriolet
    Jan 2007
    Chelmsford, Essex
    440
    The cabriolet windows are fully adjustable from inside the door skin (just had my door repainted and the bodyshop guy showed me the adjustments available).
    I'd get it checked at a dealer for correct alignment if under warranty - if not then the new Haynes manual 'might' cover cabriolet windows ???
    B6 1.8T Sport Cabriolet - Ebony Black & Red Sports Leather-19" Sportec Mono10s-Bootlip spoiler-One touch roof module-Green Cotton filter-Forge 007 - 2007 rear lamps-2007 OEM interior dimming compass mirror-OEM S4 heated, elec folding, dimming aluminium door mirrors-2007 RS4 cabriolet exhaust-2007 RS4 Carbon trim-2007 RS4 starter button-2007 RS4 inner door handles- A4 DTM carbon front splitter
    1994 UK MX5 in rare Laguna Blue
    2003 Yamaha R1 (5PW) Tech Silver - not standard !
    goodhixy's Avatar
    Nov 2007
    14
    Thanks for the responses - got it booked in for tomorrow on it's last day of warranty
    Jun 2007
    Waterlooville, Hampshire
    23
    Hi,
    Any joy at the dealer, I have the same noise but I thought it was coming from the passager sunvisor light or in and around that area. feedback would be good before i go totally mad
    goodhixy's Avatar
    Nov 2007
    14
    Yes, dealer sorted it in 5 mins while I waited - he mentioned something about a silicon gel or something - sorry I can't be more specific...but all fine now
    Oct 2005
    Lancashire UK
    202
    There was a large thread about this some time ago. I know it's fixed but, it's the top seal that runs at the top of the door. Every 6 months apply a good quality rubber/vinyl protector to all the seals and that will keep it at bay. The noise may come back after using silicon grease.
    Also, with mine I pulled the window frame outwards too whilst the window was down. An Audi tech told me the solution some years ago. That's of the lubricant alone doesn't help!!!
    2001 - Silver A4 1.9TDi Sport
    Jun 2007
    23
    Cheers for that, I'll give it a go.
    Steve.
