Chris NottEM Tuning
    Aug 2006
    NI
    785
    removing avant rear bumper
    hey all, is it hard to remove the rear bumper? need to fit some reverse sensors and a towbar oh joy
    thanks all
    back to boost, oh how I missed thee....
    technics100's Avatar
    Feb 2004
    Co Antrim
    772
    I fitted a towbar to my previous saloon, wasn't as bad as I had thought. Took about 3 1/2 hours, but didn't have to take the wheels of or remove the lights as previously thought. heres a rough runthrough of what to do.
    1)Remove the spare wheel compartment cover.
    2)Remove the two nuts holding the black plastic trunk trim, just behind the spare.
    3)Remove the four luggage net hold down clips.
    4)Peel back the carpet from around the sides which is also pushed under the black plastic trunk trim. This is spring clipped in place. There are also two plastic screw clips in the top of the liner above the shock towers.
    5)Behind the trim you will now see a vertical line of four nuts with plastic point covers on the protruding bolts. (Beneath the rear lights)There are also two more of these in a vertical line inboard of the four. (six total each side)pull off the plastic cap and remove the nuts.
    6)Remove two screws underneath the valance, in board of the exhausts attaching the valance to the frame.
    7)Remove two Torx screws each side inside the wheel well holding the carpet liner in place.
    8)Remove the Torx screw that is behind the liner. This holds the valance.
    9) Pull the sides of the lower bumper away from the side of the car.
    10)The whole unit will now pull off in one piece.
    Fit the towbar and then re-install everything
    Hope its of some use..
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    Aug 2006
    NI
    785
    superb thanks! youre a local lad too I see?
    Feb 2004
    Co Antrim
    772
    yeah from Jordanstown, just outside belfast... even better you drive a amulet avant just like me...small world
    Aug 2006
    NI
    785
    glengormley myself mate
    Aug 2006
    NI
    785
    some arty photos there too mate btw.
