Monster MotorsportBadger5
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    HEADLIGHT VENTS.
    My headlights both steam up. Plenty of condensation,this happened after fitting xenons,took lights out cleaned them,removed seals and cleaned and put back,still the same.Where are the vents? i cant seem to find any,these are self venting 2002 A4 B6
    Nickynibbles's Avatar
    Damn it where's 7th gear when you need it?!
    Jun 2007
    Hampshire
    846
    When did you clean them? Your other post on this was only a day ago & in this weather they're not likely to dry out quickly if they breathing again! I dont suppose when you did the xenon conversion you got out the mastic sealant did you? This will cause air-tightness and hence fogging up. If you've still got the problem suggest a 2-3mm drill hole in both bottom corners of the headlight unit at the back to give you some air flow.
    A4 3.0 Quattro Sport - Gone & missed everyday!
    Current road going missile.....
    ........Smart Roadster - arguably the most fun you can have in a car without using lube!!
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    didnt use any sealant,but id love to know where exactly the vents are.
    phil1978's Avatar
    Dec 2004
    Home of the white stilleto
    183
    Read the reply to your other post regarding this
    07 A4 Cab 2.0T FSI S-Line
    06 Suzuki GSXR750 K6
    Gone But Not Forgotten:
    04 A4 Tdi Quattro Sport
    03 Golf GTI T
    If in doubt go flat out
