AH FabricationsVolks Autos
Results 1 to 12 of 12
    Sep 2007
    Swindon Wilts
    170
    A4 B6 Replacement Stereo Fascia (single din)
    Hi
    Just replaced my standard concert stereo with a nice clarion dvd jobbie. However the fascia I picked on my Ebay is ****e. There is no way to lock it in, so when I fit the cage to it, I can pull out the whole system!!
    Anyone know of a decent fascia that a) fits, and b) is held in place some how!???
    Its an 02 model by the way.
    Paul
    Jun 2003
    World of my own
    9,813
    The fascia doesn't hold the HU in, the cage does that. The fascia is purely cosmetic to hide the gaps.
    I got mine from CAD:
    http://www.caraudiodirect.co.uk/audi...tor-p-662.html
    It's a very good match & fit.
    jase0851's Avatar
    Oct 2004
    yorks
    778
    andy the genuine ones are 12 quid and they have the ali strip along the top
    EBONY PEARL 2003 1.8T SPORT GMBH 190 AVANT 19" GALLARDO,S S4 SILVER SILK NAPPA HEATED RECARO,S MATT ALI MIRRORS,O.CT INTAKE PIPE, B7 DTM VOTEX SKIRTS, HYPERBOOST HX DIVERTER VALVE, RS4 DOORCARDS+TRIGGERS, AUTO-DIMMING REAR VIEW MIRROR, RS4 BRUSHED ALI TRIM, RS4 START BUTTON, PIPERCROSS PANEL FILTER, RIEGER INFINITY FRONT BUMPER:: NOW REMAP,D TO 240 ISH BHP OMG WHAT A DIFFERENCE
    Sep 2007
    Swindon Wilts
    170
    so what doesthe cage fit to?
    i'd expect the fascia to be fitted to the car somehow otherwise a scrote will simply pull the lot out.
    Just ordered one from VAG. Although it does say its for an 03 and b7! Looks same shape tho.
    andyccr's Avatar
    2003 1.8T Sport Ebony Black A4 Cabriolet
    Jan 2007
    Chelmsford, Essex
    440
    No, the aftermarket B6/B7 ones use the aftermarket radio cage to hold them in. The B5 and TT ones have small screws in them to hold the pieces in place.
    B6 1.8T Sport Cabriolet - Ebony Black & Red Sports Leather-19" Sportec Mono10s-Bootlip spoiler-One touch roof module-Green Cotton filter-Forge 007 - 2007 rear lamps-2007 OEM interior dimming compass mirror-OEM S4 heated, elec folding, dimming aluminium door mirrors-2007 RS4 cabriolet exhaust-2007 RS4 Carbon trim-2007 RS4 starter button-2007 RS4 inner door handles- A4 DTM carbon front splitter
    1994 UK MX5 in rare Laguna Blue
    2003 Yamaha R1 (5PW) Tech Silver - not standard !
    Jun 2003
    World of my own
    9,813
    The aftermarket cage uses all the metal tabs to secure it in place, you need to ensure they are locking into the many gaps around the fascia, in the B6 you need to push them in to lock them as the gaps aren't in the normal places.
    Aug 2006
    NI
    785
    I found on my B6 that none of the tabs on the cage would actually grip anything.
    having the same problem my stereo will just slide out.
    back to boost, oh how I missed thee....
    Sep 2007
    Swindon Wilts
    170
    glad Im not the only one! I was starting to think I was a numpty!
    I'm hoping the fascia from VAG can be screwed in or something!
    Jun 2003
    World of my own
    9,813
    None of the fascia's have anything to do with the HU, let alone hold it in.
    The cage is the problem you need to try harder, use the bigger flaps and push them right in with sone long nosed pliers.
    Aug 2006
    NI
    785
    Im not talking about the fascia, with the cage I have there is nowhere for the tabs to grip. your cage may have more longer tabs, but mine blows.
    Ive been fitting radios for years and never came across this
    Jun 2003
    World of my own
    9,813
    All cages are pretty standard, you have an array of small thin tabs, which admittedly can't grip anything, then you also have more substantial tabs further in. There's a few of these that will find a hole to hold onto.
    Sep 2007
    Swindon Wilts
    170
    on the VAG parts website you can buy a fascia with the silver trim at the top. Its says its for 2003 on but fits my 52 perfectly. This has 2 lugs on the inside that you screw into the dash inside the hole. Now my stereo is fitted properly ;-)
