Badger5JMB Retrofits
Results 1 to 8 of 8
Thread: S4 Tappets
    Oct 2007
    Edinburgh
    27
    S4 Tappets
    Hiya guys
    My S4 occasionally at startup from cold. gives a small amount of tappet rattle for a second or two. Anyone else come accross this with theirs?
    Its a 2003 4.2 V8. Was thinking of dropping the oil, and using engine flush, although the car is on long life 20K service intervals, and isnt due a service. Anyone come accross this with theirs?
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    .. id scrap the longlife service, especially on a monster engine like yours!!!
    Oct 2004
    Birmingham, UK
    97
    Its the cam chain tensioners rattling. A common occurence on S4's. They rattle due to oil pressure initially being low. Had mine for 3yrs now and it has always done it. There is a tech bulletin, US, for this and other owners have had the fault rectified under warranty. Its a big job to remedy, engine out job.
    Oct 2007
    Edinburgh
    27
    Quote Originally Posted by J7USS
    Yeah Im not going to keep it on them. Seems way to long to me, but I suppose if it was ever going to be an issue, Audi would not have the intervals set in such a way.
    Quote Originally Posted by Tendaimwari
    Oh well, as mines out of warranty i guess thats that. It makes me cringe when i start it in the morning. And you say that yours has always done it and not got any worse?
    Aug 2004
    Aberdeenshire
    740
    I'd get off of the Longlife servicing as the oil is a lighter viscosity than used on the normal service schedule.
    You may find that with a heavier oil the problem goes away as the oil pressure should be higher on startup.
    HTH
    Oct 2004
    Birmingham, UK
    97
    Red face
    @ VDT: It has not got any worse. Also it sounds the same if the car has not been driven for 1 day or 1 week. Some only notice the noise after long periods. I sometimes let the engine turn over a couple of time to allow oil pressure to build up. This does work but the problem is the engine tends to fire up straight away.
    I tend to change my oil in between recommended service intervals. Currently on AVS plan which uses VW504, 0W-30 or 5w-30 oil, very thin. Ideally I would prefer ot be on a fixed service plan which uses either 0w-40 or 5w-40 oil. This may help reduce the rattle but will not cure the problem as the problem is that oil pressure tensioners loose oil pressure when left standing.
    Mar 2007
    184
    cam chain tensioner 100% quite a common problem on audi/vw engines
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Yeah mine does it in the mroning too. Sounds rough for couple of seconds though!
