Badger5Chris Nott
Results 1 to 7 of 7
    veccyj's Avatar
    Jul 2004
    NOTTINGHAM
    22
    Question OIL WARNING LIGHT BUT PLENTY IN????
    Hi long time reader in need of assistance, i have owned a 3.0 V6 Quattro for 3 weeks now (A3 1.8T gone) and runs like a dream, however, the min oil warning light keeps coming on the dash every couple of days. Always check the level and according to the dipstick it doesn't even need topping up? Anyone out there know if this is a sensor fault or any help to cure most appreciated.
    jase0851's Avatar
    Oct 2004
    yorks
    782
    run a vag-com check see if it shows up. and it will tell you exactly what fault it is
    EBONY PEARL 2003 1.8T SPORT GMBH 190 AVANT 19" GALLARDO,S S4 SILVER SILK NAPPA HEATED RECARO,S MATT ALI MIRRORS,O.CT INTAKE PIPE, B7 DTM VOTEX SKIRTS, HYPERBOOST HX DIVERTER VALVE, RS4 DOORCARDS+TRIGGERS, AUTO-DIMMING REAR VIEW MIRROR, RS4 BRUSHED ALI TRIM, RS4 START BUTTON, PIPERCROSS PANEL FILTER, RIEGER INFINITY FRONT BUMPER:: NOW REMAP,D TO 240 ISH BHP OMG WHAT A DIFFERENCE
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Be careful mate, I found out the expensive way....
    See my thread Audi A4 1.8t (8E) engine swap with TT Engine
    Mar 2007
    184
    hello mate
    i had posted a thread about this, but did'nt say the previous problems i had,
    i regulary get the low oil light, discovered its down to the type of driveing, and short drives anyway, before hand i had the oil level sender changed, at the advice of audi, 3-4000miles later, and get another warning, audi topped up the oil and sent me on my way, 5-6000miles later just before the service i get another warning, audi put this down to a dash problem, with no errors listed???? stange but the senior tech said this was the problem,
    got a good second hand one off ebay and had it fitted, also had the milage corrected, a new unit is £300 plus and second hand one cost me £50 nice.
    had the car serviced and dash fitted, and 5-6000miles later... get another warning,
    took the car stright to audi who did a head check and every other check they could and could'nt fault the car.
    in the recent thread i had i've learnt its a audi thing common on high mile cars, and audi are aware of this problem and changing all there oil types for older cars,
    my advice is do the cheapest thing first, a oil change and sensor change
    and see how it goes
    also does your oil pressure light go out straight away?
    veccyj's Avatar
    Jul 2004
    NOTTINGHAM
    22
    The oil pressure light goes out straight away as normal, think i will try the oil level sensor first, is this a diy job?
    Mar 2007
    184
    its normally on the bottom of the sump, with a couple of bolts, you'll have to change the oil and filter at the same time as you'll loose it,
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    I had exactly the same problem on my 2001 Audi A4 3.0 Quattro Sport that I bought in 2003.
    After driving around 50-60 miles as a continuous trip the orange “Oil Level Low” text warning came on the dash board. This is not to be confused with a red oil pressure warning which did not light. Oil level looked fine from the dipstick, but did top up a little to be on the cautious side. I was also aware that too much oil can also damage your engine! The warning went away after I got back in the car and started the engine.
    Fortunately the car still had ~12 months warranty, so I took it down to my local Audi dealer and explained the problem. In their infinite wisdom, they advised that the oil level was Ok?!
    50 miles further the next day – no surprise “Oil Level Low” and the oil level according to the dipstick was OK. Started the engine again warning gone. Perhaps a duff sender unit I thought? Anyway back to Audi for the day. They then advised that this was a known fault on A4 3.0 V6 engines – problem with software in the ECU.
    Couple days later they changed the ECU under warranty and the problem was solved.
    Also what I was told by the Audi technician, is that opening the bonnet resets any related errors and they are re-checked a further 50 miles down the road. If you stop/start the engine this counter is also reset. This is why errors flagged up got reset and you may think you have solved the problem. This type of error may not show up on short trips either since you need to do 50+ miles.
    (I recently had a look into my ECU area housing, the Motronic box says Year of Manf. 2001, and the ECU YOM=2003.)
    So it sounds like you may have this “old” ECU Software problem??
