Chris NottBadger5
    May 2007
    65
    Rear door light not working
    Rear passanger door light is not working and is not picked up by the DIS the interior light does not come on when this door is opened. Can someone suggest what the problem might be and what is needed to fix this..
    Nickynibbles's Avatar
    Damn it where's 7th gear when you need it?!
    Jun 2007
    Hampshire
    846
    Propably the door plunger switch. Have a look at the door near the hinges & you'll see a plunger switch, if it dosent do anything when you push it in & out a few times, try taking the switch out of the door & bridges the wires. If the lights still dont come on then its more than likely a wiring fault somewhere which would need vag-com or an automotive electrician to track down where the fault lies.
    A4 3.0 Quattro Sport - Gone & missed everyday!
    Current road going missile.....
    ........Smart Roadster - arguably the most fun you can have in a car without using lube!!
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    There isnt a plunger on there its a microswitch built into the lock.Very commom problem on VAG cars.
    Have a look...
    door lights???
    technics100's Avatar
    Feb 2004
    Co Antrim
    773
    Mine is doing the same thing, where is the microswith in the lock? is is hard to get out or is it a whole door out job?
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    Mar 2007
    184
    hello mate
    i ended up haveing to change the complete lock easy to do but can be expensive if you cant get a salvage part?
