Thread: A4 SPRINGS?
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    A4 SPRINGS?
    Ive been told coil springs out of a A4 2.0 TDI (B7) will fit A4 1.9 TDI (B6) my car is standard A4 1.9 TDI (not even an se) the springs are from an S-line TDI, how low will my car sit with the s-line springs?
    Also what difference are springs from a s-line and from a sport ,are the the same height?
    jase0851's Avatar
    Oct 2004
    yorks
    782
    should be 25mm lower. i thought the suspension was the same on s-line and sport
    EBONY PEARL 2003 1.8T SPORT GMBH 190 AVANT 19" GALLARDO,S S4 SILVER SILK NAPPA HEATED RECARO,S MATT ALI MIRRORS,O.CT INTAKE PIPE, B7 DTM VOTEX SKIRTS, HYPERBOOST HX DIVERTER VALVE, RS4 DOORCARDS+TRIGGERS, AUTO-DIMMING REAR VIEW MIRROR, RS4 BRUSHED ALI TRIM, RS4 START BUTTON, PIPERCROSS PANEL FILTER, RIEGER INFINITY FRONT BUMPER:: NOW REMAP,D TO 240 ISH BHP OMG WHAT A DIFFERENCE
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    S-Line is lower than sport.
    53 A4 2.5TDi Quattro Sport 180 Tiptronic. Heated Buffalino leather, DVD Sat Nav RNS-E, TV, Bluetooth, 6 cd, BOSE, Colour DIS, Cruise Control, Auto lights and mirrors, Interior light pack, Heated mirrors.
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Not sure you want to go lower on the standard shocks.They are really crap.
    vw754's Avatar
    Nov 2006
    U.K
    1,973
    can i use s-line springs on my standard shocks?
    do i need to replace/cut-short the bump stops?
    if sport is 25mm lower,how low is the s-line springs?
    finally will camber adjustments need to be made?
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Quote Originally Posted by vw754
    I wouldnt use anything apart from standard springs with standard shocks.
    You can shorten the bumpstops for a little more clearance but if your dampers are too soft it will still bang on them.
    Not sure on the difference on the ride height.
    You should always get your camber checked when changing steering or suspension components.
