Chris NottBadger5
    Nov 2007
    20
    HELP! A4 1.9TDI Passenger side
    Hi i got a problem on my audi a4 b6 if anyone could help me
    the passenger sidefront and rear doors have no electrics on the central locking or the electric windows.
    any help appreciated thanx
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,974
    open passenger door and where the hinges are you will see rubber tubing which carries all the wiring,in time as your door is opened and shut alot this can break the wires!
    slide the tubing/sleeve back and check the wires.
    Nov 2007
    20
    Quote Originally Posted by vw754
    Hi thanx for your reply but i have already checked the wiring in the sleeve
    i forgot to mention these are new doors that are having the problems...the drivers side is working dont know whats wrong...
    any more suggestions
    thanx
    vw754's Avatar
    Nov 2006
    U.K
    1,974
    have ya tried wiring in drivers side just in case,if you had doors on you must ave left sumat unplugged,try inside the front door a few plugs in there or in the panel passenger side (the kick panel )obvious no pwer....nothing that side is plugged in.
