    Aug 2007
    brake pedal switch
    can anyone help? my brake lights weren't working, hooked up vag-com which said the brake pedal switch wasn't working. just replaced the switch and the lights stay on all the time now!
    anyone have an idea how to fix it?
    Silver Quattro's Avatar
    1st Quattro Deffo not my last...
    Sep 2007
    Somewhere In The Middle
    100
    Had same situation on mine not long ago after braking lights wouldnt go out,had brake light switch changed problem sorted,maybe a duff switch you've had installed or not installed correctly.
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    A common problem is the switch needs to be rotate a bit more if your brake lights are stuck on after changing the switch.
    technics100's Avatar
    Feb 2004
    Co Antrim
    773
    Quote Originally Posted by timps
    same thing happened to me, you have to really twist the switch until it locks into place and clicks...its easy to do if you remove the lower half of the dash..
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    Aug 2007
    27
    I had this fault the day I got my A4 home! Replaced the switch the next morning having found out the fault from this website!!
    You have to keep twisting till you think it's done, and then twist some more! When it goes in, it gives a fully satisfying CLICK
    Jun 2007
    24
    I had the same problem when I tried changing the switch, rear window brakelight stayed on.
    As I remember it turned out one of the bulbs had blown(I think) and the other one had fallen out of the holder...?? Wasnt able to get the new switch to work but kept the old one instead. (btw there was no twisting left in the new one...?)
    All those flashing lights were letting me know my bulbs were faulty-too simple for me...
