JMB RetrofitsChris Nott
    Feb 2003
    Symphony Upgrade
    Just bought a symphony Audio system from a 2002 A4 and I would like to fit it to my 2002 A4 which currently just has a Chorus System in. Is it possible? Is it a big job? What other parts will I need?
    Any instructions/advice would be great
    Thanks in anticipation
    Steve
    Anito's Avatar
    Dec 2003
    Chester
    429
    Re: Symphony Upgrade
    If your replacing single DIN to Single DIN then I expect it to be a simple job.
    If the new one is double DIN, then you'll need a new facia / console. - They cost a few quid.
    75
    Steve,
    Is this the symphony HU with built in 6 CD changer?
    If so it is double din size and therefore you will require a double din size hole to put it in.
    Any chance of a photo of the back of the Symphony Head Unit? In my instruction book it says the head unit can accept another CD changer (other than the inbuilt one), so I just wanted to check by looking at the various connections on the back!
    Nick
    75
    See the attached pics
    75
    Dude, I also have found out that the "02 A4 uses the CAN bus for illumination thus if you want to light up the display you'll need to hardwire it. I found a post on audiworld forums. Do a search for Symphony A4.
    Cheers & Good luck [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
