Chris NottBadger5
Results 1 to 7 of 7
Thread: Wheels rubbing
    Jul 2004
    Bridgend, South Wales
    47
    Wheels rubbing
    I have a 2.5tdi quattro se and have recently fitted a set of 18's et35 with 225/40/18 rubber. I noticed a couple of days ago that the front of the front wheelarches have been worn away slightly and snapped the small mudflaps also. It has to be the wheels rubbing against the arches but they don't touch anywhere on full lock and they don't seem to touch when the suspension is under duress, but obviously must do.
    I was wondering whether anyone else has had a similar problem?
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    They shouldn't be rubbing, how wide are they?
    Built in Germany, Perfected in England
    Jul 2004
    47
    8j wide. i think they are rubbing from the inside of the wheel when on full lock, whist cornering.
    Jan 2007
    Laaaaandan
    263
    Is the offset (ET) value correct, perhaps you need spacers?
    jase0851's Avatar
    Oct 2004
    yorks
    782
    dont have any probs with mine and they are 235/35/19 same offset aswell
    Jul 2004
    47
    as far as i'm aware et35 should be fine
    Randomjim's Avatar
    Aug 2006
    Sussex, Uk
    2,747
    That offset is fine, maybe you should take a wheel off an check the offset's correct. Normally it's stamped on the inside of one of the spokes.
