Hi all,
After getting the orange engine managment light cleared last week (the guy told me it was just a blip?) it has reared its ugly head again. The car seems to be running fine so I took it back and got a rundown of the DTC's. The print out reads as follows:
#1 fault: 16486 : Air mass meter -G70:signal too low Sporadic fault.
#2 fault: 18062 : Please interrogate fault memory of combi-instrument Sporadic fault. (When this was looked at it came back with 'coolant temp gauge sender -G2 Open/short circuit to positive/sporadic fault).**
#3 fault:16795 secondary air system through flow defective
#4 Error in mapped cooling system(usually temp sensor or thermostat)
**This fault is the only one I'm aware of as the temp gauge flits around sometimes*Easy fix?
I also have a coolant leak which ive had the car up on ramps and its coming from the back of the engine below a large black pipe about 5 inches from the top of the engine. its pretty conjested to attack it from the top? is there anything to watch out for when removing pipes/wiring?
So needless to say I'm a bit worried about the volume of faults!
Also I'm finding it harder to get into gear when stationary, especially first and reverse, its not too bad if I'm moving slowly but sometimes when I stop I have to force it in.??
any help would be appreciated!
Cheers.
2002 A4 1.8T quattro sport.52,000 miles
Cheers.
