Results 1 to 8 of 8
    jase0851's Avatar
    Oct 2004
    yorks
    782
    how do i get rid of sludge
    i have a small build up of sludge can i get rid of it with a forte flush and a couple of 3000 mile oil changes ? cheers
    Elberoth's Avatar
    Feb 2007
    Poland
    70
    Try Auto-RX.
    www.auto-rx.com
    Audi A4 B6 1.8T
    Go: Sportec K04 Stage II | ATP manifold | Milltek cat-back | Dual IC | JJ TIP | Ecode TP | S4 rear sway | Brembo ORO rotors | Ferodo DS2500 pads
    Show: full S4 body conversion | bi-xenons
    jase0851's Avatar
    Oct 2004
    yorks
    782
    have u used it elb ?
    bubstar's Avatar
    Jul 2004
    Surrey
    546
    Thumbs up
    Quote Originally Posted by jase0851
    I would say that's a good plan Jase
    I don't like the idea of adding products to oil. At least after flushing and a couple of changes you should be rid of any muck.
    Another reason to do an annual or 10k oil change using fully synthetic.
    AVS = Poo
    BUB
    A4 Avant S-Line quattro - Avus Silver/Silver Half Leather *240ps*346nm* - a few choice mods. Now Stared up ;-)
    Elberoth's Avatar
    Feb 2007
    Poland
    70
    Never used it presonally. Some ppl from Audizine.com reported good resoults though.
    Audi A4 B6 1.8T
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    In short, sludge is uncurable but it can be stopped if it is detected early. Auto-RX is your best bet like Elberoth said.
    Hope it works for you because sludge can cause oil pump failure which is not good for your car or wallet.
    jase0851's Avatar
    Oct 2004
    yorks
    782
    cheers lads ill av a go and tell you how i get on
    jase0851's Avatar
    Oct 2004
    yorks
    782
    i need to change the computer to fixed servicing as my cars been on the dreaded avs servicing since new, its had 5 services in 80k which isnt to bad i suppose
