Sky InsuranceAH Fabrications
Results 1 to 22 of 22
    Aug 2007
    30
    Audi Concert System
    Hello,
    I have an A4 with the audi concert system fitted and am cosidering putting in an aftermarket stereo.
    The clarity and power of the concert system is great. Will this still be the same if i replace the standard head unit with a high end after market stereo?
    Is the concert system basically a speaker upgrade?
    Otis
    Jun 2003
    World of my own
    9,813
    Concert is the brandname of the HU, just like Symphony or Delta. It is not anything to do with the overall system. The only upgrade to the stock system is Bose.
    They are all basically low end Matsu****a (Panasonic) units with an earth shattering 2 x 20w output. The rear/sub amp provides a further 2 x 20w for the rears and 50w for the sub. These are peak figures so RMS will be nearly half that.
    Any aftermarket unit will be twice the power at least, but it is advisable to rewire the rear speakers to the new HU to balance the sound.
    Aug 2007
    30
    Thanks for the reply.
    What kind of wiring harness do i need to buy to attach my new head unit?
    Halfrauds say it needs to be an active harness, is that correct?
    Regards
    Otis
    Aug 2007
    30
    Quote Originally Posted by AndyMac
    Regards
    Otis
    Jun 2003
    World of my own
    9,813
    There are 2 harness adapters available, either RCA input or speaker input. If you have rear RCA's on the new HU then you need the RCA input adapter.
    No RCA's then you need the speaker input adapter.
    The adapter is only for the rear speakers and sub. The fronts just plug straight into the new HU.
    Either way the rears will be really quiet compared to the fronts.
    Aug 2007
    30
    harness adapter wiring.
    Hello,
    I ordered an harness adapter from my local car audio shop, plugged it all in and theres a slight problem.
    The front and rear speakers work but there is no sound from the sub.
    When i investigated, the problem became clear. The block that comes out of the wiring loom in the car has about 6 cables going into it. However, the connector on the harness that it goes into only has about 3 cables coming out of it. I can only presume the other cables are for the sub etc.
    Heres a pic:
    http://i41.photobucket.com/albums/e3...MAGE_00115.jpg
    Is there another type of harness adapter available with the Sub woofer wiring on it too or do i need to get my souldering iron out?
    Regards
    Otis
    Jun 2003
    World of my own
    9,813
    The sub works off the rear pre-outs same as the rear amp. They share the same feed as well as the same amp, so if the rears are working then the sub has to be as well.
    As already mentioned you will have to fade to rear to balance the sound as the new HU will have at least twice the power going to the fronts as the rear/sub amp. On mine I had to fade 80% to rear to get a balanced sound so in the end by passed the Audi amp altogether and fitted a stealth sub with a proper amp.
    Mar 2007
    Leeds, UK
    74
    Respect is due
    Aug 2007
    30
    OK, i have decided to go for an aftermarket sub, amp and head unit.
    If i fit this with, am i right in thinking i will have just the 4 standard door speakers + my sub?
    Will the standard tweeters work also?
    I dont want to go out and put in an new head unit and sub and lost any quality of sound. Dont want to end up with a big bass box!
    Regards
    Otis
    jase0851's Avatar
    Oct 2004
    yorks
    782
    i put a pioneer deh-p9400mp headunit in my car and under andymacs advice i ran wires from the headunit to the connector which plugs into the rear amp so the rears would work instead of an adapter, now all the speakers work apart from the sub which i aint bothered about as i have a 12" rockford sat in my back room ready to go in when i have time. the sound quality is far better than it was
    Aug 2007
    30
    This sounds like a plan!
    Im not very good with that kind of thing though....can anyone give me a step by step guide that i can pass to my local auto elec guy?
    Regards and thanks in advance.
    Otis
    jase0851's Avatar
    Oct 2004
    yorks
    782
    pm sent mate
    Sep 2007
    Swindon Wilts
    170
    could I have a copy of this detail if possible please?
    Oct 2007
    10
    Quote Originally Posted by jase0851
    pm sent mate
    me 2 please.
    Higgsy's Avatar
    Hard To Spin
    Jockland
    95
    could i grab one of them too please? cheers
    defsix's Avatar
    149
    you might be waiting a while. That last post is over 3 years old.
    AUDI A4 Avant 1.9TDi Sport
    | RS4 RARB - RS6 18" - SLCR Spolier - HID's / Laminex / DRL's - Ext LED lighting - Ambient Lighting F+R - Dension300 / iPod Touch - Siemens Bluetooth - DIS - Cruise|
    Higgsy's Avatar
    Hard To Spin
    Jockland
    95
    ahh i see, it came up in recent posts tho, thats why i didnt even look at the date....weird
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    The forum got spammed last night by a handbag salesman - hence it appeared in recent posts!
    defsix's Avatar
    149
    I was wondering why a few old posts popped up with no replys... were they nice handbags ?
    Higgsy's Avatar
    Hard To Spin
    Jockland
    95
    shame, i was looking for a nice Fucci....
    Dec 2010
    :niah
    Dec 2010
    :niah:
