Volks AutosSky Insurance
Results 1 to 8 of 8
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    S4 ARB's or RS4 ARB's
    I know some peeps have replaced their stock ARB's to stop excessive body roll, but which is the best to go for?
    Are the RS4 ARB's OTT? Have you found any degredation in grip?
    Are the S4 ARB's a better compromise, ie more body roll than RS4, but better overall grip?
    I'm worried that the RS4 ARB will make the car too stiff and result in an earlier loss of grip - or the back end stepping out too quickly, or maybe causing understeer. What are your thoughts?
    Those that went for S4 ARB's - do you wish you'd gone for the RS4's.
    Those that went for RS4 ARB's - do you wish you'd gone for the S4's?
    53 A4 2.5TDi Quattro Sport 180 Tiptronic. Heated Buffalino leather, DVD Sat Nav RNS-E, TV, Bluetooth, 6 cd, BOSE, Colour DIS, Cruise Control, Auto lights and mirrors, Interior light pack, Heated mirrors.
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    I had RS4 on mine and it was great.Bodyroll was terrible before i fitted it.
    Very glad i didnt go S4.
    RS4 all the way,you wont regret it.
    Jan 2007
    Laaaaandan
    263
    Are you talking just fitting just the rear, or replacing both?
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    rear on mine.
    Mar 2004
    Manchester
    1,306
    I'd guessed that both would need upgrading. Is it advisable to just do one end? I would have thought doing the front as that's where the bulk of the weight is?
    Jan 2007
    Laaaaandan
    263
    If you do just the rear, you'll actually end up with a little less understeer. Having a front end that is "too" stiff will increase understeer. It depends on what you want to do. Another way of reducing body roll would of course be to run stiffer (and lower) springs/ shocks.
    Mar 2004
    Manchester
    1,306
    Cheers, I don't want to run stiffer springs/shocks. I'm on the sport suspension, and I find that too hard as it is. British roads just aren't good enough, so I find myself rattling my teeth out on my commute to work. It's just the body roll I need to sort out. Sounds like I should opt for the rear arb only then?
    bubstar's Avatar
    Jul 2004
    Surrey
    546
    Quote Originally Posted by arthurfuxake
    Another vote for the RS4 22mm DRC bar.
    As I've said again and again you can't go wrong with this mod' for the money.
    Changing the rear anti roll bar will not have an affect on comfort at all.
    There's no need to change the front bar, all the A4's use the same one.
    A4 Avant S-Line quattro - Avus Silver/Silver Half Leather *240ps*346nm* - a few choice mods. Now Stared up ;-)
