EM TuningMonster Motorsport
    Jan 2007
    Laaaaandan
    263
    Xenon headlight/ sidelight cluster removal
    Hi there
    I've got to replace my sidelight bulbs in my stock Xenons on my V6 - I can get at the right side bulb holder no problem by removing the flexible section of the air intake, but getting to the left hand side light is somewhat tricky/ impossible. Any tips for getting to it/ removing the light cluster?
    Aug 2004
    Aberdeenshire
    740
    I had no issues changing both in-situ on our 1.9 PD130. In fact the LHS one was easier than the right!
    Are you unable to get the cover off? Is there something in the way that's maybe not there on a diesel?
    VTEC_Killer's Avatar
    Oct 2006
    West Yorkshire
    78
    It'll be easier take the headlight unit out; there are 2 screws you take out and 2 at the back of unit which you loosen up BUT don't take out completly; the headlight will slide out forward once done - easy!
    2004 Audi A4 1.9TDi Sport with GMbH Bodykit
    RNS-E, Parking Sensors, Privacy Glass, Xenons
    Jan 2007
    Laaaaandan
    263
    Did this job this morning, took 5mins in the end - it was the vanity panel that was in the way, but that was a simple job to remove, and I was able to squeeze my hands in the gap ok...
    I now have a pair of the Philips Blue halogen sidelights to more closely colour match my Xenons. Will have a look at the colour difference when it gets dark!
