    Jan 2007
    Laaaaandan
    263
    3.0 v6 oil consumption
    Do any fellow 3.0 V6 drivers have any advice/ experience of oil consumption rates? My low oil level warning light came on at the weekend (shamefully I confess to not having checked the oil level for the last 6 months bad I know). I've only driven about 6000 miles in the last year, is that a "normal" level of oil use. Put in 1 litre of Mobil 1 0w-40 and I think it's fine now - although the dipstick is really hard to read!
    Nickynibbles's Avatar
    Damn it where's 7th gear when you need it?!
    Jun 2007
    Hampshire
    846
    I've probably used about 1.5ltrs in the past year & a bit of owning the car and having done 12,000 miles now. Not a spec of oil anywhere on the engine so guessing the engine does use a little oil & the dealer hasnt mentioned anything when it was in with them a few months ago having the cats changed.
    A4 3.0 Quattro Sport - Gone & missed everyday!
    Current road going missile.....
    ........Smart Roadster - arguably the most fun you can have in a car without using lube!!
    Happy Trails!
    May 2007
    Ombersley
    3.0 V6 oil consumption
    Had the 3.0 V6 for about 12 months now and have covered 16,000 miles 2 x service oil changes and regular top up with Texaco Havoline Synthetic 5W-40. This is expensive but well worth it. Did a 1600 round trip to Chantonnay (France) with no fuss and little regard for fuel economy ...
    Worth a Try?
    Happy Trails
    Jan 2007
    Laaaaandan
    263
    I also can see no sign of oil leakage, although I did think my tailpipes looked a bit on the black side after an 800mile round trip to the Lake District (which is when the low level light came on), again with a similar disregard for fuel economy. Spirited driving I think it's also called Will keep an eye out on this but it sounds like a litre in 12months isn't unusual?
    Jul 2007
    Surrey
    34
    I had to top mine up by half a litre when I first got it. Oil and filter change done 2k ago and no oil required since. I did do a search on this and other forums and oil consumption is by no means unusual - and a litre in 12 months is getting off lightly
