Badger5EM Tuning
    FrankG's Avatar
    Ireland
    160
    Rear brake light bulb removal! - How to?
    anyone here know how to access the non driver side rear light cluster on an avant, haven't had time to look myself, just thought I'd see if anyone here has any experience, going to change it tomorrow. Also will I have to plug it in to a diagnostic equipment to get rid of the message on the DIS?
    TIA.....
    Audi - Lord OF The Rings
    2004 Audi A4 1.8T 163bhp S-Line Avant
    2004 Audi A4 1.8T 190bhp S-Line saloon
    2001 Audi A4 1.8T 150bhp saloon
    2002 Audi A3 1.6 Ambition
    Jun 2003
    World of my own
    9,813
    It's pretty easy, but not obvious. On the inside of the boot trim there's a small blanking plate covering a screw hole. Remove that and undo the screw. The screw should hold itself in the hole without falling out and down behind the trim. You then have to lever the back of the light cluster out from the side bodywork, as it is held in by 2 pegs, and then wiggle the whole thing free. I use a a thin strip of metal covered in tape to prise out the back of the cluster (the bit nearest the front of the car) without damaging the paintwork.
    Or you could do as Audi suggest and only let an Audi dealer replace the 50p bulb for you for around 20!!!!
    the DIS warning cancels itself, no need for VAGCOM.
    Mcgough's Avatar
    Oct 2004
    Newcastle
    820
    Erm audi charge £76 for a rear bulb!
    Frank its really simple, unless you have no eyes and no hands then you should be alright!
    2010 A4 Avant B8 S-Line Executive 143ps 2.0 Tdi Ice Silver
    Extras - 5 spoke 18's, Comfort Pack, Electric Seats, Start-Stop, alcantara/leather, Silver Stitching, Factory Tints all round, Cruise control, symphony 6 disc changer, mobile phone prep low
    Previously Owned 2002 Red A4 Avant Quattro Tdi 130 , 2004 Red A4 Avant Quattro Tdi 130
    Jun 2003
    World of my own
    9,813
    You are joking right?
    They charged me £38 once to change a dash bulb (during a service), so I was being conservative as a brake light is slightly less complicated. Unbelievable.
    FrankG's Avatar
    Ireland
    160
    Thanks lads, a piece of cake, very easy to do, took only 5 minutes, daylight robbery if the dealer is charging that much, especially when they don't need to hook up the dianostics. Very impressed the way the DIS informs you which bulb has blow. Agains Ta for the reply's.
