Badger5Monster Motorsport
Results 1 to 14 of 14
    Niknak's Avatar
    Oct 2006
    manchester
    864
    Air Bag Warning Light
    Hi guys, I have changed my front seats over, and now I have an air bag warning light, the connectors are all in correctly, any ideas?
    Ian
    jase0851's Avatar
    Oct 2004
    yorks
    782
    did you disconnect the battery ian
    jase0851's Avatar
    Oct 2004
    yorks
    782
    are the plugs pushed down as far as they can go cos mine had only moved a couple if mil and they set the bag light of
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    When changing the seats, you should always disconnect the negative terminal on the battery, so as to avoid the risk of the airbag being deployed and also the warning light will come on.
    It may well be connected properly butthe fault is stored in the ECU.Try disconnecting the battery for an hour or so to see if it makes any difference. If not you'll have to get VagCom to clear the code.
    Niknak's Avatar
    Oct 2006
    manchester
    864
    Yeah I disconnected the battery as not to set the airbags off.
    I have checked the connectors and they are all plugged in correctly??
    Any ideas?
    Niknak's Avatar
    Oct 2006
    manchester
    864
    I thought it was the positive you needed to disconnect?? I have totally disconnected the battery now so I will see in an hour??
    Quote Originally Posted by golf
    Jun 2003
    World of my own
    9,813
    Either will do it but normally use the earth otherwise there's a danger of the +ve lead touching the bodywork which can cause issues with sensitive electronics. Regardless, when you rechecked the airbag connections they may be OK but the fault will still be stored in the ECU.
    Niknak's Avatar
    Oct 2006
    manchester
    864
    Damm I feel a trip to Awesome tomorrow then! I take it the airbags will be ok, no danger of them going pop at 70 down the motorway?
    Cheers guys
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    The airbags will be fine, but just try not to have an accident! You may or may not have your face rearranged by the steering wheel.
    Niknak's Avatar
    Oct 2006
    manchester
    864
    lol now thats reassuring to know, cheers Golf
    jase0851's Avatar
    Oct 2004
    yorks
    782
    when the dash bag light is on all the airbags are turned of
    doogleman's Avatar
    Jul 2007
    Ireland
    96
    Id say you'd have to vag-com it to clear that error now man.
    Niknak's Avatar
    Oct 2006
    manchester
    864
    Awesome can't do it till Monday next week, anyone with VAG-COM near Manchester?
    jase0851's Avatar
    Oct 2004
    yorks
    782
    buy a lead and do it yourself ian i am gonna
