Niknak
Hi guys, I have changed my front seats over, and now I have an air bag warning light, the connectors are all in correctly, any ideas?
Ian
Ian
golf said:When changing the seats, you should always disconnect the negative terminal on the battery, so as to avoid the risk of the airbag being deployed and also the warning light will come on.
It may well be connected properly butthe fault is stored in the ECU.Try disconnecting the battery for an hour or so to see if it makes any difference. If not you'll have to get VagCom to clear the code.
