EM TuningChris Nott
Results 1 to 12 of 12
    Jun 2007
    For Sunroof Owners
    Guys,
    When sunroof is opened and all windows closed im experiancing winf noise in the cabin. When opeing a window a little this stops. The wind deteror on the sunroof seems to be fine. Have any of you experienced this and what is the solution?
    Ek
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    Its not different to my GOlf, I have the same problem.
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Same here I think, Ill check when it stops bloody raining!!
    Aug 2004
    Aberdeenshire
    740
    Is it like a pulsing that affects your eardrums quite a bit? If so I've never had a sunroof equipped car that didn't do it.
    Haven't had a sunroof for years now simply because of that.
    Jun 2007
    Correct like that pulsing effect - i guess you just have to have another window slighty open to have the sunroof open...
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    Its just an air pressure build up. With the Golf the roof opens to a position where buffeting is minimal, or you can make it open completly. The faster you go the more it hurts your ears. The A4's i've been looking at don't have them so i'm thinking of having one retro fitted at a later date
    Les 51's Avatar
    A pint of Diesel please!
    Feb 2007
    Cambridge
    687
    It's because the vents in the boot (if they're in the boot on an Audi) are not opening enough. on my Mondeo I took the covers off them and that helps, if you have a look at them you may find you can prop them open to relieve the pressure.
    LISTEN TO THE Bluehorses THEY ROCK!
    Apr 2007
    SE UK
    26
    Quote Originally Posted by Ekkie
    You've just answered your own question
    Used to happen in my Golf with the sunroof open. Open a rear window a few mm, problem solved.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    This happens in every car, even an old Sierra I had used to do it.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Apr 2007
    SE UK
    26
    I remember a couple of guys on the uk-mkivs.net forum posting about sunrooves and rear windows blowing out, bit extreme but that was somehow linked to pressure build-up.
    So, probably best to go for the open window solution......
    stoakseya4's Avatar
    Aug 2005
    Kent, UK
    1,227
    It starts (on mine) from about 35mph, through to about 50-55mph, then stops.
    Therefore the trick is never drop below 55mph !
    1998 S4 Widebody Saloon Track Car
    2006 320d SE Touring - Ze Fuhrer's Wagon
    2001 B5 RS4 510bhp & 508ft lbs SOLD
    1.9TDI (130) Sport -Black-Revo - Mrs Stoakseya4's mota - SOLD
    Nickynibbles's Avatar
    Damn it where's 7th gear when you need it?!
    Jun 2007
    Hampshire
    846
    Or dont have the roof open, just tilt it & then there is no problem! Well thats what I do anyway!
    A4 3.0 Quattro Sport - Gone & missed everyday!
    Current road going missile.....
    ........Smart Roadster - arguably the most fun you can have in a car without using lube!!
