EM TuningMonster Motorsport
Thread: Vag-Com code
    Nickynibbles's Avatar
    Damn it where's 7th gear when you need it?!
    Jun 2007
    Hampshire
    846
    Vag-Com code
    Got my Vag-Com finally up and running this evening without resorting to launching the laptop down the road! Anyway, wanted to check the climate control on my '02 A4 3.0 Quattro Sport as its not cold despite having a regas a few weeks ago. Was expecting to have a high pressure sensor error as others have noted but instead I got:
    01809 - Actuating Motor for Temperature Flap: Left (V158)
    41-10-Blocked or No Voltage - Intermittent
    01842 - Shareware Version. To Decode all DTCs
    30-10-Please Register/Activate - Intermittent
    So what on earths that all about then??? Help would be much apprectiated!
    A4 3.0 Quattro Sport - Gone & missed everyday!
    Current road going missile.....
    ........Smart Roadster - arguably the most fun you can have in a car without using lube!!
    Jun 2007
    Hampshire
    846
    OK, my local Audi stealership say there are a couple of motors in the airbox that control flaps directing the cold and warm air to where it needs to go. Likely the one for the cold air is jammed/knackered and so not getting the nice cold air I need! So does anyone know where these control flaps will be located? Are they gonna be in the engine bay under the windscreen or inside the dash??Thanks.
