Chris NottAH Fabrications
Results 1 to 7 of 7
    DIA
    Mar 2007
    Coolant leak from under my car?
    I have a 2002 a4 cab and I keep going low on coolant nearly every day. I now realise there is a crack on the plastic cover underneath the front of the car and thats where it looks to be leaking from. Does anybody what it could be and how much to repair?
    Audi A4 1.8TQ
    Sep 2004
    South West
    130
    Quote Originally Posted by DIA
    The plastic thing underneath is the undertray, this will have nothing to do with water leak, it just looks like its leaking from it.
    What engine do you have, some weak points I have found on the 1.8T are
    On the rear of the engine there is a jacket that divides up the water outlets, this is prone to splitting, it's a ****e job to change, cost me approx 150 quid as mine went big time.
    On the front of the car under the radiator is a metal pipe that runs most of the way accross the front, it rusts and splits
    Could be a pipe has split, you can see most of the pipes on 1.8t have a prod about.
    hth
    And how is education supposed to make me feel smarter? Besides, every time I learn something new, it pushes some old stuff out of my brain. Remember when I took that home winemaking course, and I forgot how to drive?
    petewon's Avatar
    Dec 2004
    Newcastle
    514
    Quote Originally Posted by ronny
    Thats what went on mine, the rubber seal went hard and cracked,it was fully draining all coolant daily. Cost me about 80 to have it replaced and was apparently a pig of a job.
    DIA
    Mar 2007
    Thanks for the reply guys! But since that post ive had a coach hit my car while it was parked up, and to top it off the f****r drove off. So my cars sitting in the garage at the mo while im sorting the insurance claim out. By the way i have 2.4 engine.
    Audi A4 1.8TQ
    Sep 2004
    South West
    130
    Jeez, you dont have no luck sorry to hear about the drive off... at least you could now say the water leak wasnt there before the crash, although I never said that
    sniperlover's Avatar
    Aug 2006
    198
    Leak
    i had the same problem with my audi there flange in the middle of the engine, after a while the flange will crack due to the heat from the engine.This common with most a4.so it should be ok.
    DIA
    Mar 2007
    Sent my car into audi today for assesment. Told them when i went to see my car after the smash there was loads of water coming out the front. They said they'll look at it and deal with it, And they gave me a 56 plate A4 2.0TDi S-Line as a courtesy - NICE!
