Chris NottVolks Autos
Results 1 to 9 of 9
    russgt's Avatar
    Mar 2007
    60
    Question about aircon re-gas
    Should I ideally drain the remaining refrgerant from the aircon system just because it needs a top up? Is there a certain life of the gas? afterall its just gas
    I realise the R134a refrigerant should contain a lubricant to prolong the life of the compressor internals, so therefore would this item sold on ebay be ok http://cgi.ebay.co.uk/INTERDYNAMICS-...QQcmdZViewItem providing I have no leaks and fill to the correct pressure?
    I have attempted to phone around local companys/garages for the re-gas, however, they want around 90 of my hard earned dosh for this simple task
    Thanks all
    Jun 2003
    World of my own
    9,813
    You can get it done properly for around £65 at an AC specialist, so is it really worth £30 to risk a DIY job? Damage to any of the AC components (compressor/dryer etc) means big money at around £400 to replace each item.
    The gas lasts forever, just like a fridge, but in a car it will eventually bleed through the mechanics so needs regassing every 4-5 years.
    Regassing is not just topping the system up.
    Feb 2007
    Warwickshire
    46
    Don't risk it. I had mine done last Sunday by a mobile specialist for £50. Bloody cold now.
    He says it needs to be emptied with the exact amount according to spec replacing it. Look in your local paper or something alot more people then you think are doing it now.
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    Mine also needs doing, the cars not even 4 years old yet. My wife's 99 ford fiesta 1.25 zetec is blowing freezing cold, and it's never been regassed!
    53 A4 2.5TDi Quattro Sport 180 Tiptronic. Heated Buffalino leather, DVD Sat Nav RNS-E, TV, Bluetooth, 6 cd, BOSE, Colour DIS, Cruise Control, Auto lights and mirrors, Interior light pack, Heated mirrors.
    Jun 2003
    World of my own
    9,813
    All down to number of hours used, not age of car. 4-5 years is estimate based on 12k miles per year with CC on all the time. Actually turning the CC off for long periods shortens the life as well.
    Mar 2005
    Scotland
    91
    unfortunately you cant empty all the gas and refill. the system is like any other in a fridge/freezer etc and if the gas is removed/leaks untill nothing is left, the system would need put on a vaccum pump to remove all moisture/air in there. If you have already bought a top up can, give it a bash and see how it goes.
    A specialist would remove all the gas, put the system on a vac pump, then weigh IN the correct amount of 134a along with some lube and probably a dye to make it easyer to find any leaks under a UV light in the future. Thats where your ££'s go. Everyone has to make a living!
    Mar 2004
    Manchester
    1,306
    That does concern me. I've heard that the aircon should be run once in a while during winter so that it lubes all the seals etc. Is it the same with climate control? During winter when the outside temp is say 0, how would you turn the air-con on? The climate control will just pump the cold air in from outside because it is cold enough to drop the temp inside the car, so the air-con is not needed.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    The compressor will still run as it removes the moisture from the air, even when its set on hot
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Jun 2003
    World of my own
    9,813
    Yes with CC it's on all the time regardles of temp. Only way to switch it off is to press ECON or the snowflake (depending on model). Which is why you never get steamed up windows in winter.
