JMB RetrofitsSky Insurance
Results 1 to 7 of 7
    Oct 2005
    ireland
    89
    Pleeeease Help!!!
    I have run over a wooden plank on the way home. It tore off the underbody attached to the underbody of the engine bay (about 1/3 way down the underside)
    There is also a leak now dripping a clear, odourless liquid and I don't know whether I should commute my 180 mile round trip in it tomorrow or not
    Any help would be greatly appreciated, especially in what that underbody covered (transmission, exhaust maybe??), and what the leak could be
    Cheers guys
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Do you mean it tore off the belly pan?
    The belly pan is the plastic protective cover underneath the engine bay. There are two main ones which are under the engine.
    That clear, odourless liquid sounds like water. Where is it leaking from?
    Oct 2005
    ireland
    89
    Two pans from what I could see, one directly under the engine, the other attached to it heading back towards the centre of the underbelly. Couldn't see much with just a jack, no way I was getting under it!
    The leak is coming through the plastic covering on the passenger side underbelly, dripping around the middle of the car
    I all important fluids in the car have at least a colour or a smell then where could the water be coming from, window wash? rad?
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    Funny how people underestimate the importance of plain old water, until they're stuck on the hard shoulder in the freezing rain with a seized engine that is.
    53 A4 2.5TDi Quattro Sport 180 Tiptronic. Heated Buffalino leather, DVD Sat Nav RNS-E, TV, Bluetooth, 6 cd, BOSE, Colour DIS, Cruise Control, Auto lights and mirrors, Interior light pack, Heated mirrors.
    Oct 2005
    ireland
    89
    Leak has ceased, mechanic mate checked it out, refitted the engine pan with ties and drove it 90 miles to work today...all seems OK...needs service next week so will get a better look when up on jacks, whatever.
    Next question, where is the best place to source 2 new underbody pans with clips to replaced bashed ones??
    worpspeed's Avatar
    a41.9tdi/zenons/s line kit/rs4 rims/eibach springs
    Sep 2006
    southampton
    45
    hi there
    that clear liquid will be water. it is condinsation developed from the aircon and it drips out via a overflow pipe in the centre of the car just behind the gearbox .
    i hope this helps
    DIA
    Mar 2007
    I've got a leak from the same place., and yes it is my coolant water. Hopefully mine should be getting repaired by dealers as my cars in with them after the mishap it had with a coach. If they don't sort it i guess i'm f****d!
