AH FabricationsChris Nott
Results 1 to 10 of 10
    baynesey's Avatar
    well you better unsell them, sharpish!
    Mar 2007
    Stevenage, Herts
    194
    Service Indicator Reset
    Hello,
    Been meaning to have the garage reset my service indicator for a while now (was serviced by them but they never reset it) but I cant be arsed to go over to them (40 mile round trip) is there a way I can do it myself with a sequence of button presses, like the Golfs?
    Chris
    2003 2.0 FSI SE A4 Avant
    Jun 2007
    24
    Yes there is. Its very simple. It gets rid of the message when you start up though, wont keep record of when next service is due.
    Unfortunately I cant find the info needed to reset the service message.
    It has to do with turning key in ignition (one or two clicks, but not starting car) while pressing the trip/miles button??
    Have a search throuogh forum and check tdiclub.com.
    Sorry I am not much help... but I am sure someone else will be on with your info.
    Good Luck
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    It tells you in the manual how to do it.
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Quote Originally Posted by golf
    ********,i forgot about that one again.
    baynesey's Avatar
    Mar 2007
    Stevenage, Herts
    194
    I can't read
    Will look into over the weekend
    Jun 2007
    24
    I knew I had the relevant info somewhere...
    ...and its not mentioned in my manual as far as I can see.
    This is from a thread on another forum.
    The link is at:
    http://forums.audiworld.com/a4/msgs/615688.phtml
    "28. How do I reset the oil service interval light w/out the use of a VAG-Tool?
    With key in the off position, push and hold in both clock and odometer stalks, start car. That's it."
    I dont know if there is a need to actually start the car... but it should resolve the issue for you.
    And to correct myself on a previous post, they say on that forum it takes about 300 miles for the next service interval to register (something else I didnt know, until now...)
    Vin
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    It should be in your manual.
    With the key in off position press and hold the spanner button,turn ign on let go of spanner button and press reset.
    Voila.
    baynesey's Avatar
    Mar 2007
    Stevenage, Herts
    194
    Quote Originally Posted by james0808
    Voila.
    and Robert's ya Muvva's Bruvva
    cheers
    C
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    this puts you onto fixed servicing though, the variable gets binned.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
