Volks AutosAH Fabrications
    D8UGF's Avatar
    Oct 2006
    Lanark
    107
    Need your help chaps
    Got a problem with my spare remote key fob, it will not open the central locking, it will switch off the immobiliser when in the ignition and it turns off the alarm when the door is unlocked manually with the key. Any ideas what might be wrong? I put a new battery in it but it is still the same, I dont want to try to re-sync the keys in case I make a balls off it and stop the good one working!!
    Dougie
    Nickynibbles's Avatar
    Damn it where's 7th gear when you need it?!
    Jun 2007
    Hampshire
    846
    The central locking key code needs to be re-programmed via vag-com, thats all.
    A4 3.0 Quattro Sport - Gone & missed everyday!
    Current road going missile.....
    ........Smart Roadster - arguably the most fun you can have in a car without using lube!!
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Yep, exactly what mine needed to. Job done...
