Chris NottMonster Motorsport
Results 1 to 12 of 12
    GFORCE's Avatar
    Bring On The Sunshine
    Dec 2006
    95
    How do I know what Brake Discs to order?
    Hi All,
    I need a new set of front Discs and Pads and I am not sure how to find out if I need the 288 x 25mm Vented Discs or the 312 x 25mm vented discs.
    I am guessing 312mm discs ?
    Does anyone know?
    P.S B6 2003 Audi A4 1.8T Sport Cabriolet
    2003 Audi A4 1.8T T-Sport Cabriolet
    Rolling on 19" RS6's (NOW FOR SALE ...GUTTED!!)
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Probably be 288mm but if you give GSF your VIN number then they'll tell you what discs you need. Or measure them.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    I might be wrong on this but i think the 312mm had vented rear discs not solid???
    a4sline190's Avatar
    Nov 2004
    Scotland
    149
    My Sline has vented 312 x 25 mm fronts but solid rears 255 x 12- 04 plate.
    Elberoth's Avatar
    Feb 2007
    Poland
    70
    312mm are OE on 3.0
    288mm are OE on all 1.8Ts
    You can upgrade from 288mm rotors to 312mm rotors (which is worthwile) - all you need are two 3.0 mounting brakets for the front calipers. everything is bolt on.
    Audi A4 B6 1.8T
    Go: Sportec K04 Stage II | ATP manifold | Milltek cat-back | Dual IC | JJ TIP | Ecode TP | S4 rear sway | Brembo ORO rotors | Ferodo DS2500 pads
    Show: full S4 body conversion | bi-xenons
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Quote Originally Posted by Elberoth
    How can they be when a4sline190 has 312mm???
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Well I have 345mm on my tdi so
    Chris
    See my images @
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Quote Originally Posted by A4Quattro
    Show off.
    Elberoth's Avatar
    Feb 2007
    Poland
    70
    Quote Originally Posted by james0808
    Then A4 190hp (engine code BEX) is the exception. You can also buy 345mm brakes from the B6 S4 or 320mm brakes from the B7 A4.
    Audi A4 B6 1.8T
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Show off.
    All down to you James, couldn't have done it without you....
    Chris
    See my images @
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Glad i could help.
    GFORCE's Avatar
    Dec 2006
    95
    thanks for your help guys
