Badger5EM Tuning
Thread: temp gauge
    A4 Avant 130 Tdi
    Feb 2007
    Retford,Notts
    31
    Angry temp gauge
    hello all
    having problems with my temp gauge( A4 avant TDI ) it works ok for a while then for no reason doesn't work then while traveling it jumps from nothing to normal opperating temp then doesn't work at all for a few days then starts working again. then the hole thing starts again it works then it doesn't it jumps up and down like a nutter then it works then it doesn't its doing my head in
    has anyone else had this problem is it just a fauilty sender on the block or is it something more sinister
    Jun 2003
    World of my own
    9,813
    Faulty sender, common problem, £18 from a dealer, DIY fix.
    Elberoth's Avatar
    Feb 2007
    Poland
    70
    Check out the Vag-Com for codes. The coolant temp sensor may be shot. Cost pennies to replace.
    Audi A4 B6 1.8T
    Go: Sportec K04 Stage II | ATP manifold | Milltek cat-back | Dual IC | JJ TIP | Ecode TP | S4 rear sway | Brembo ORO rotors | Ferodo DS2500 pads
    Show: full S4 body conversion | bi-xenons
