JMB RetrofitsBadger5
    Dec 2006
    56
    QUICK QUESTION! - Wheels
    Can you confirm that the wheels from a 2004 Audi A3 with fit on a B6.
    RickT
    Dec 2006
    56
    i have read that the offset on the A4 B6 is 35mm..
    Can you confirm the offset on the A3 2004 onwards?
    RicKT
    Niknak's Avatar
    Oct 2006
    manchester
    864
    Rick
    A3 wheels won't fit on an A4 due to them having a diff offset.
    Ian
    Apr 2007
    16
    Wheel help
    Technically your A3 wheels will fit, but will sit slightly closer to the brakes and the body of the car - offset on the new A3 would be ET42 + These will work ok and shouldnt really affect the handling that much - tho a 5mm spacer might be a help.
    Niknak's Avatar
    Oct 2006
    manchester
    864
    I thought the PCD's are diff A3 110 - 112 on an A4
