EM TuningChris Nott
Results 1 to 28 of 28
    technics100's Avatar
    Feb 2004
    Co Antrim
    772
    Question about colour coding bumpers
    I just got a quote to get my bumpers colour coded for the avant. The quote was Ł400 + vat, I thought this was a bit dear. Anyone else had this done? He also wanted to remove the bumpers and side trims!!! is that the way its done or can it be sprayed with everything on the car?
    2003 Silver A2 1.4 TDi - 65mpg & Ł30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    It can be done with the bumpers still on the car, but it's a lot of hassle as everything will need to be covered up and masked off. The price seems slightly expensive if not unreasonably high.
    To save money remove the bumpers yourself, that way you only pay for the spraying and you know they wont be harsh on your car, ie yanking bits if they dont come off.
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Ł400 + vat is too much IMO.
    Before I added my kit, My bumpers were left on but I took my sides off as they are less hassle than the bumpers to remove. Cant see point taking bumpers off. Spend Half hour masking it up is easier than taking everything off.
    As said few times previous threads, My cousin can colour code yours for Ł150 - Ł200 if the person is situated near to leicester and dont mind travelling. but I see that you are a long way away so Id be searching for some cheaper quotes.
    I wouldnt pay that.
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Quote Originally Posted by J7USS
    That is a very good price.
    I paid Ł300 to get both bumpers(top and bottom halfs),both side skirts,bottoms of the doors and the spoiler painted.
    Ł400 + vat is expensive.
    Mar 2007
    184
    i paid Ł200 on top of the Ł675ish my work paid out for a new bumper, and front end respray, but i got the door flares, sill extentions, the rear bumper, and a piller all the way down too the rear arches, only leaving the doors,
    removed everything myself though to get round all the corners, quite easy, only took a couple of hours removing everything, took a hell lot longer putting everything back on,
    the labour is the most costly thing.
    Feb 2004
    Co Antrim
    772
    Bumpers
    Quote Originally Posted by james0808
    Did you remove any of the items or leave them all on the car?
    How hard is it to remove all the bits - bumpers, skirts etc. I have removed the rear bumper before to fit a towbar, but haven't done the front or skirts..
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Quote Originally Posted by technics100
    Yes i removed the bumpers.
    Front bumper is quite easy,remove both headlights,there are 3 nuts to undo down each side and you need to undo the two bolts at the front holding the bumper to the crash bar.Also all the little screws holding the plastic bits on.
    Side skirts are easy,remove the top cover and undo all the screws on the skirts,top and bottom.
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    There are some pictures and a write up on here.....
    http://www.a4mods.com/index.php?page...erremoval.html
    Feb 2004
    Co Antrim
    772
    thanks, did you split the bumpers in two when removed? i.e. took the black bit off the painted bit? don't suppose you have a write up on removing the skirts..
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Yes they was painted seperate on mine.
    No write up on the skirts but it only takes 5 mins to get them off.
    Lift the top cover with a screwdriver and pull it off.Then just undo all the torx screws under it and under the side of the car,there are quite a few but thats it.
    Mar 2007
    184
    your better of removing everything and pulling it apart, i.e: seperating the bumper into 2 halfs, you'll get a better finish rather than it looking all over sprayed, might take a bit longer but worth the extra time!!!!
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    nah Shove all that, Just get them to mask it out, Spray the bumpers on but sideskirts off. When colourcoding mine before kit, We just popped the edges of the bumpers out by loosening a few bolts. Job done.
    Feb 2004
    Co Antrim
    772
    Went to another car place today, they are doing it for £250-275, I have to take the skirts off but leave the bumpers on, they will fit the skirts back on..hopefully it will change the car...a bit
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Went to another car place today, they are doing it for Ł250-275, I have to take the skirts off but leave the bumpers on, they will fit the skirts back on..hopefully it will change the car...a bit
    Thats much better.It will change the car...alot.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,313
    Has anyone in the Bexleyheath area of North Kent/South East London had this done? If so, where did you go, and how much did you pay?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Sorted, GO for it mate, Thats a fair deal. Transformation will amaze you. You'll see!!
    Feb 2004
    Co Antrim
    772
    i think i also need matt finish chrome mirrors and some s-line badges, that should be her done....hopefully
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    I had my mirrors done in Matt, defo a good choice.
    Still thinking about the Sline Badges though.
    Apr 2007
    SE UK
    26
    I've just had a quote from my local bodyshop to colour code my A4 Avant - around Ł400 to remove the front & rear bumpers and side skirts, and another Ł450 to prepare and spray.
    Grand total of around Ł850!
    Do I win a prize for finding the most expensive bodyshop in the UK?
    Feb 2004
    Co Antrim
    772
    I think so, mines booked in the week after next, they are leaving the bumpers on but I have to remove the skirts, although their re-fitting them. £250 nice.. Chrome Matt mirros have been bought along with s-line badges, will wait until I get it painted to put them on...
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    I think so, mines booked in the week after next, they are leaving the bumpers on but I have to remove the skirts, although their re-fitting them. Ł250 nice.. Chrome Matt mirros have been bought along with s-line badges, will wait until I get it painted to put them on...
    Which side is having the chrome then Technics??
    Mcgough's Avatar
    Oct 2004
    Newcastle
    820
    I payed £110 for the rear bumper to be sprayed at audi !!
    and i payed £400 for the reiger front bumper and skirts to be fitted and sprayed at audi!
    so thats way to much mate!!
    2010 A4 Avant B8 S-Line Executive 143ps 2.0 Tdi Ice Silver
    Extras - 5 spoke 18's, Comfort Pack, Electric Seats, Start-Stop, alcantara/leather, Silver Stitching, Factory Tints all round, Cruise control, symphony 6 disc changer, mobile phone prep low
    Previously Owned 2002 Red A4 Avant Quattro Tdi 130 , 2004 Red A4 Avant Quattro Tdi 130
    Apr 2007
    SE UK
    26
    Got another quote today to colour code front and rear lower bumpers and side strips and tint rear passenger windows, rear 3/4 windows and rear windscreen for Ł550 all in.
    Think I know where my next Ł550's going.....
    Mcgough's Avatar
    Oct 2004
    Newcastle
    820
    Thats ok i suppose, thats around £350 for the work and £200 for the tints, i payed £185 for my tints all round
    May 2006
    perth
    380
    I have mione booked in for Monday and is costing me Ł250 but not sure how he plans to do the work, may ask now! Expensive month this week just bought 18's to replace my 16's New battrey today and to be tax and MOT by the end of the month!!!
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Quote Originally Posted by samuelt
    I know the feeling mate, both my cars tax and MOT finished this month. The road tax for the Audi was an eye watering Ł112.75 for 6 months, and the MOT was Ł50 + (Ł40 brake pads and fitting, Ł22 wiper blades). Insurance was due for renewal on the Golf too. My savings have taken a hammering!
  28. #27
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Ł112.75....really...
    Bloody 'ell. Mines up end of this month too.
  29. #28
    May 2006
    perth
    380
    Just seen my car in the paintshop yard, all the side parts have been removed but the bumpers are still on. I know this guy specialises in paint repair/resprays so may be planing to mask of the bumpers rather than take them off. he has also filled and is spraying a large stone chip (approx 1cm by 4cm) on the rear wheel arch that happend 1 day after i got the car!
