Volks AutosAH Fabrications
Results 1 to 19 of 19
Thread: Whiffy Air-con
    henry74's Avatar
    Feb 2007
    Verwood, Dorset
    115
    Whiffy Air-con
    Hi All,
    I'm a forum virgin so be gentle with me! i just wanted a second opinion (or more!) on a problem i've got with my air-con. When first turned on I get a smell from the vents that can only be described as stinking like the laundry pile in an old peoples home the day before wash-day! It lasts for anywhere between 30 seconds and 1 minute. I've changed the pollen filter as a work colleague had had the same problem and that did the trick. However i'm still getting the same old pong. I'm guessing the system might need re-gassing but was just interested if anyone else has had the same problem? Any comments gratefully received.
    technics100's Avatar
    Feb 2004
    Co Antrim
    773
    The smell is from bacteria and mould that has built up over time in the vents and pipes of your heater system. You can get cans of cleaner which you spray in the car and put the air con on recirculation mode, it sucks the spray through the system and eliminates the smell. some found on ebay (i think halfords do it to)
    http://cgi.ebay.co.uk/CARPLAN-Car-Ai...QQcmdZViewItem
    Mine has the same smell, must get round to doing this...
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    henry74's Avatar
    Feb 2007
    Verwood, Dorset
    115
    Many thanks for that info! I was going to Halfords tomorrow night to get some mountain bike goodies so i'll have a look for that CarPlan cleaner at the same time. I'll just have to remember to have the drivers window open when i start the car in the morning or i might bring up my Crunchy Nuts!
    pav-g's Avatar
    Jan 2007
    Bradford
    728
    Yeah the pong is common with most cars equiped with ac - usually caused by lack of use - thats why manufactures usually suggest usuing the ac frequently - but hey sods law who wants to use it in winter when its already bloody freezing. I didnt know you can get something to neutralise the smell - let us know what the sprays called when you go to halfords. Cheers
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    You can still use AC when it's cold - it's fecking great at clearing misted up windows on cold or wet mornings. Only problem is that when you switch it off, they mist up again!!
    Justin
    2001 VW Golf 2.3 V5 (170) Highline, Indigo Blue - standard, for now...
    A4 (B5) SE with a few slight amendments here and there (sold)
    spuddie007's Avatar
    Thomas the Tank Engine - Choo, Choo!
    Feb 2005
    Barnet, Hertfordshire
    210
    Have the same problem - just got one from the man on ebay above....
    Thanks technics.......
    Was an Audi S3, Pre-Facelift 210 bhp, Security Tints, Standard spec, simple sweet and to the point.
    Currently a Golf GT TDi 170 DSG in Pearlescent Black with every conceivable extra available - company car
    From June 2011 - Audi A3 Sportback Black Edition 140 tdi (company car) with DSG gearbox, Technology Pack + AMI, Storage Pack, Open Sky Roof System, Comfort Pack, Luggage Pack and Interior Light pack. Oh and it's Monza Silver. Can't wait
    WHITEY_1's Avatar
    Bugz Champion, Starship Legend Champion
    Jan 2006
    S-Wales
    229
    I have the same problem to but not to the piont that it stinking like the laundry pile like henry
    henry74's Avatar
    Feb 2007
    Verwood, Dorset
    115
    Well guys i've just used a can of Comma Air Conditioning Cleaner (11.99 from Halfrauds!) to see if that does the trick. I'm going to give it an hour or so and then start her up - keep your fingers crossed! I'll report back later with hopefully positive results.
    Richard
    '98 A4 2.4 SE
    Apr 2007
    Nr. Sheffield, UK
    99
    I bought some spray from Euro Car Parts tonight (around 10). You turn the air con off, then spray it into all the vents and then also into the air intake under the pollen filter. You let it sit for 15 minutes, then drive for 2km with the air con off, then turn it back on again.
    Seems a bit conveluted to me... But I'm hoping it'll work.
    WHITEY_1's Avatar
    Jan 2006
    S-Wales
    229
    Henry just bought exactly the same as you at 3.30 today, I did it about 4.30 and I think its a load of ****! I did exactly what it said on the tin but the only thing I havent done is change the filter for the air conditioning, BUT I do not know where this is on my car! If anyone knows can you let me know? Thanks
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Its next to the battery.
    WHITEY_1's Avatar
    Jan 2006
    S-Wales
    229
    thanks james
    i just started it this morning and it still smells the same, its got to be the filter needs changing. Ill check it later on today
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    I used this stuff and although it did clean out my air con it left a sticky residue everywhere! all over the vents/dash etc.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    henry74's Avatar
    Feb 2007
    Verwood, Dorset
    115
    The news is not good! Having followed the instructions to the letter there is a small improvement. However the stench is still quite strong when the air-con is first turned on and is still always present to some degree. What really annoys me is that i've been using the air-con right throughout the winter since buying the car in September (approx 9500 miles). Does anybody know of a good air-con specialist in the East Dorset/Bournemouth/Poole area?
    Mcgough's Avatar
    Oct 2004
    Newcastle
    820
    Problem with the audi is that the aircon does not close fully when switched off!!
    I made Audi clean mine and flush the system under warrenty- as there is nothing in the write up and serivce schedual about this so they they are to fault, they wanted £79 but i rang customer services and they agreed it should be in service book.
    In future they told me to run the econ mode for last 2 mins of my journey that allows the aircon to switch of and the bacteria to be blown/flushed out- no problems since on all my cars!!
    2010 A4 Avant B8 S-Line Executive 143ps 2.0 Tdi Ice Silver
    Extras - 5 spoke 18's, Comfort Pack, Electric Seats, Start-Stop, alcantara/leather, Silver Stitching, Factory Tints all round, Cruise control, symphony 6 disc changer, mobile phone prep low
    Previously Owned 2002 Red A4 Avant Quattro Tdi 130 , 2004 Red A4 Avant Quattro Tdi 130
    Mar 2005
    uk scotland
    13
    get a/c coil cleaner and spray onto cooling coils then flush away with water
    Mar 2005
    uk scotland
    13
    for got to say after flushing you can spray an antifungal just like used in commercial fridges . cut out bacteria
    (fridge engineer)
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Quote Originally Posted by dive007
    The cooling coils are deep under the dashboard!
    Chris
    See my images @
    henry74's Avatar
    Feb 2007
    Verwood, Dorset
    115
    Well it's coming up to nearly a week since i've hopefully cured the problem! The Comma stuff from Halfords was crap - didn't really make any difference and left residue all over the dash and windows! Apparently the stuff to use is made by Forte and is pretty potent. In the end i got the entire system flushed, lubricated and re-gassed for 90 inc. vat at the local Masterfit garage. Now that the smell of the cleaner has subsided everything seems ok (touch wood!). Thanks to everybody who offered advice - hopefully yours never gets as bad as mine was!
