AH FabricationsEM Tuning
Results 1 to 7 of 7
    Light Speed's Avatar
    Buff my shiny red one...
    Nov 2006
    Central Scotland
    63
    Question Parrot CK3200 into A4?
    Bought a Parrot CK3200 car kit at the weekend and hoping to fit it shortly - anyone else fitted these and was it fairly straight forward?
    It's a 2004 with the standard single CD player (not Bose) - there's plenty of threads on here but most seem to refer to the A3 or Bose versions which seems to need extra wiring. Will mine be 'plug and play' or will I need an extra adapter or wiring (there was some mention of needing to tap into a switched supply from the fuse box).
    Any help appreciated
    Cheers!
    Audi A4 Avant S Line 190 | Brilliant Red
    technics100's Avatar
    Feb 2004
    Co Antrim
    775
    I just fitted a Parrot ck3000 evo tonight, I had to take an ignition feed from the back of the fusebox and splice into the orange wire of the parrot iso loom, also put a spade plug on the yellow mute wire and put it on the mute connector on the rear of the headunit. all fully working now.. hope thats of some use..
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    andyccr's Avatar
    2003 1.8T Sport Ebony Black A4 Cabriolet
    Jan 2007
    Chelmsford, Essex
    440
    If you don't want to goto the fusebox then the fag lighter is also accessory fed. Just pop the panel out and run a lead down the side of the centre console.
    As you have a non-bose stereo that means you have non amplified front speakers and the CK3200 kit will plug in no problems. Some Concert / symphony units have the mute on the mini ISO, some have it on the main ISO plug.
    Its no problem to do, if you want somewhere to stash the 'kit' the take the glovebox out.
    Should be no more than a 1 hour job start to finish really.
    Hope this also helps
    Andy
    Feb 2007
    Warwickshire
    46
    I just had the 99 Parrot kit fitted from Halfords. Superb bit of kit.
    Nov 2006
    Central Scotland
    63
    Thanks for the info thus far chaps - I had a look at lunchtime and it's a single CD 'Concert' head unit that's in the car.
    Looks like there's some space to run the cable between the main centre console and the top part of the dash too. Just need to pop to my local audio place and ask them nicely if they'll pop the HU out with their keys for me!
    Is there a wiring diagram or some other way of finding out which pin on the back of my HU is the mute pin?
    Nov 2006
    Central Scotland
    63
    Well managed to fit the Parrot myself at the weekend - was pretty straightforward once I'd done some thinking and studied the wiring diagrams.
    Only small issue I had was finding a suitable switched 12V supply - ended up taking one from the back of the fusebox - spent a bit of time finding the right one - the first few I tried were not switched so was scratching my head wondering if I'd wired something up wrongly.
    Anyway, got there in the end and it's all working perfectly. Sound quality is crystal clear over the mic and I like the lil' display.
    Only outstanding bit is trying to decide on a permanent location for the display - at the moment I've got it just above the credit card holder on the supplied Parrot bracket. Not convinced I'll keep it there tho'
    Anyone else fitted one and where/how did you mount the display?
    Cheers!
    Nov 2006
    Central Scotland
    63
    Thumbs up
    PS Cost me 120 for the CK3200 Colour plus maybe 6 in bits for the fitting - only because I wasn't sure exactly what connectors and wiring I had at home.
