Chris NottJMB Retrofits
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,664
    HELP NEEDED! - Flat Spot/Hesitation/Misfire
    Has anyone experienced , or does anyone know what might be the cause of, this?
    I have an 2003 A4 2.4 petrol V6, the 170ps version, with a multitronic box. I used to think the multi suffered from a slight judder when taking off from a standstill, but have now realised it's not the box at all, it's the engine. What I'm experiencing is what feels like a slight misfire or throttle hesitation round about the 1800 rpm mark, the speed at which the multitronic initially holds the engine for a normal to brisk step off. It's only fleeting (certainly gone by 2000 rpm when accelerating) but if I put it in neutral & feed in just enough throttle to hold the revs around 1800 rpm, it is definitely there.
    Thoughts, anyone?
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Mar 2007
    I am experiencing exactly the same problem which became very intense at some point and totally puzzled the workshop I get my car to. They have done something to improve it but it never really got away. What they did was that they changed a few sparkplugs that seemed to gone off. Additionally the have done something with the airflow to the engine. As said..the problem never really got away, but greatly improved, it doesn't happen all the time anymore, but very rarely. Now I am facing other problems...this car was never ok at everything.
