EM TuningJMB Retrofits
Results 1 to 7 of 7
    WilkoS3's Avatar
    Dec 2004
    North West
    162
    Registration plate
    This might sound like a silly question, but what's the best way to get the reg plate off. I'm assuming that it's just stuck on? Do I need to break it to get it off?
    2003 B6 A4 Avant 1.9TDi Quattro Sport - the current ride for me and my dog.
    2002 Goodwood Green S3 225 - sold
    2000 Cabriolet 1.8 final edition - sold
    1995 B5 A4 1.8 SE - sold
    SamDude's Avatar
    Jan 2007
    London
    2,091
    There should be a couple of yellow or black 'caps' which you take off and unscrew the screw to release the plate.
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    They're normally stuck on with double sided tape, if it doesn't have any visible screw mounts just pull it, it will most likely break, but then again thats a good thing, stops people nicking your plates.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    pav-g's Avatar
    Jan 2007
    Bradford
    728
    I took mine off recently to put my private plate on - sat their with a hairdryer warming the plate hence the tape behind for a good ten minutes, my nephew came along grabbed the plate and with a bit of brute force just took it off - 10 seconds front and back. I looked like a complete fool. Good luck.
    S6 avant
    Oct 2006
    bewdley Worcestershire
    689
    if its stuck on get a walpaper scraper cover it with masking tape and carefully slide it down behind the plate all the way along to cut through the double sided tape. should be able to get it off without damage to car or plate.
    2000 s6 avant, special order met, green, satnav, Bose, tv, solar roof, privacy glass, recaro silver nappa.
    WilkoS3's Avatar
    Dec 2004
    North West
    162
    Quote Originally Posted by SteveS
    Thanks chaps I'll try this option first followed by the brute force one. I take it I'll need to use some acetone or equivalent (I don't want to take the paint off though!) to clean up the bumper ready to stick on the new plate?
    S6 avant
    Oct 2006
    689
    yeah, bit of panelwipe would be best from a local freindly bodyshop. petrol on a clean rag works too.
