AH FabricationsEM Tuning
    Nov 2003
    cruise control retro-fit
    Hi
    Have a problem with ABS/ESP lights on since I did a cruise control retro-fit
    to my Audi A4 1.9 TDI 130bhp 6-speed manual trans 2003 (Euro spec.)
    Engine code AVF gear box code GBA
    I am using hex-com and Vag-com Release 311-2
    The fitting or the cruise control is complete, clear instructions came with the kit.
    The instruction call for the car to be sent a main dealer after install.
    But I have Vag-com + hex-com lead so I am hoping to do this job myself
    Kit included stalk and new control module 8E0 953 549 P
    All I need is to sort this problem out and the job is finished
    01044 - Control module incorrectly coded 35-00
    00778 Steering angle (G85) 66-10 - not matched
    Control module 8E0 614517 ABS/ESP front 3429
    soft coding 0000 shop WSC 00000
    Attempted recode using login 09495 and recode 04395 followed by steering
    calibration.
    But not working
    Can you let me know if I am using the correct login and recode numbers
    for Control module 8E0 614517
    Please help
    yoda01
    Jun 2010
    hi,
    could realy need your help.
    ive got the same problem.
    cruise,dis fitted.
    cant get the abs coded,its staying 00000..
    also getting warnings up in the dis.
    did you figure it out?
    regards
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,258
    this may be of help, full coding instructions and explanations https://docs.google.com/fileview?id=...1NjEz&hl=en_GB, its all about working out login codes from what i have read, also this is of use http://www.tyresmoke.net/forum/audi-...ise-a4-b6.html
    pick through the info and you should be ok.
