EM TuningChris Nott
    Aug 2006
    44
    Boost leak...help required...!
    Any ideas what could be causing a boost leak in my A4 1.8T (2002). The car just deosnt seem to pull fast enough when foot is down in about 4000-5000 revs.
    I drove a mates 1.8T the other day and there seemed to be constant power at that rev range and he's isnt remapped either.
    Thanks to all in advance...
    MJCAUDI's Avatar
    Jul 2003
    Glasgow
    36
    Smile
    I had this and found my Diaphragm in the diverter valve was split. Replaced with a forge Closed Loop Diverter Valve with higher spring pressure (because of remap) and was much better.
    Good luck
    Aug 2006
    44
    Thanks for the reply.....
    My car has also been remapped and I am also using the forge diverter valve. When you say higher spring pressure, is this a modification to the valve itself or is it how the valve comes as standard? as mine was just fitted as standard out of the box.
    MJCAUDI's Avatar
    Jul 2003
    Glasgow
    36
    Heres a link to the spring kit , I have APR map and am using the yellow spring (15-23 PSI).
    Heres the link:
    http://www.forgemotorsport.co.uk/con...roduct=FMDVTUN
    also the Valve Diaphragm in the valve can also split, heres the link for the replacement:
    http://www.forgemotorsport.co.uk/con...roduct=FMND109
    check these are the right ones for your valve.
    Let us all know the cause when you find it, good luck!
    Aug 2006
    44
    Thanks again for the reply MJC.
    How did you determine which spring to go for? Mine has a star performance remap, i was quoted gain figures from 150bhp to 200 - 205 bhp. Which colour spring do you think I should go for?
    MJCAUDI's Avatar
    Jul 2003
    Glasgow
    36
    I would check the Diaphragm is not split first , then replace with the lowest rated spring ( Green one ) and see how it feels. If you feel its still lagging a little put the yellow one in. You just have to experiment a little, you dont won't the spring to be so strong so it does not release the pressure either.
    Hope this helps
