EM TuningAH Fabrications
Results 1 to 14 of 14
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    HELP! Indicators playing silly buggers!
    Just noticed the other night that when I indicate to turn right the indicators flash right once then flash left two to three times and then reset and flash right again until i switch them off. It only does it when I first start indicating.
    It doesn't do it all the time but when it does I am worried someone is gonna pull out on me because they think I am going to turn left when I am actually turning right!
    What the hell could it be, is it the relay or is it the stalk mechanism that is knackered?
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    WHITEY_1's Avatar
    Bugz Champion, Starship Legend Champion
    Jan 2006
    S-Wales
    229
    HI tech I had this problem on my n reg I was told to hit the hazard warning switch quite hard with your finger I tried it and it worked sweet as a nut! Hope this helps!
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    Quote Originally Posted by WHITEY_1
    you reckon its a loose connection then? I imagine that push the switch back onto some kind of connection?
    WHITEY_1's Avatar
    Jan 2006
    S-Wales
    229
    I dont know about a loose connection BUT i remember that before it happened i cleaned the car in side and i think where i was cleaning it {the dash} i must of jammed the hazard switch then later i went out in the car and thats when it started playing up i then came back home put a post on the forum then they told me what to do the same as i told you and it worked
    Have you gone out and tried it yet?
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    not yet, the mrs is out in it at the mo but as soon as she comes back i will try it and let you know
    WHITEY_1's Avatar
    Jan 2006
    S-Wales
    229
    Have a look at this tech
    the last post as well bit of luck m8 its just the hazards!
    Indicators not working properly
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    hi whitey, thanks for givin your comments and I have tried what you said but it hasn't made any difference. I am starting to think more and more that its the stalk thats faulty, I don't think its making the proper contact when I move it up to turn right.
    Does anyone know how much a stalk would be to replace and do you just replace the one or does it come as a unit with both stalks?
    WHITEY_1's Avatar
    Jan 2006
    S-Wales
    229
    DAMN! no problem tech hope you sort it
    46TheDoctor's Avatar
    Valentino Rossi A.K.A The Doctor
    Feb 2007
    311
    A good friend of mine is an audi technician and i put your problem too him, he said that the hazard switch is the control ecu for all your indicaters, he says he has to frequently replace these under warranty and is sure this is your problem.
    54' A4 Avant TDI130 GmBh Sport Sline-19"RS6 Alloys + SATNAV+RNS-E+ TV/D.V.D/MP3+ Colour D.I.S+ Bose Hi-Fi+Bluetooth+Heated Buffalino Leather+ Aluminium Fishscale inlays+ Xenons+ 6 disc changer+ Interior Light Pack+ Storage Pack+03'VW Bora TDI150 Sport Highline+ 05' ZX-10R Ninja
    Nov 2006
    liverpool
    703
    sounds like a promising piece of advice, hope u get it sorted easily mate
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    Quote Originally Posted by 46TheDoctor
    thanks for that mate but i think its sorted itself out.
    i noticed the other day that while i was turning the steering wheel left to go around an island i pushed the stalk upwards to turn right and there was a louder click than usual as if something snapped back into position and now the problem has stopped happening?!?!?!?!? god knows what it was but the indicators are working as they should be again....bloody cars!
    Nov 2006
    liverpool
    703
    bet audi didnt know they made self righting cars
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    Quote Originally Posted by chris_20
    don't tell 'em, they will be asking for money for that as well!!!
    Nov 2006
    liverpool
    703
    haha
