JMB RetrofitsAH Fabrications
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Common problems?
    Hey guys,
    I'm going to see a 2001 Audi A4 1.8T with 90k on the clock this coming week and I was wondering what problems I should look out for?
    Having had the same engine in my current Golf, I'm fairly clued up as to how it works and that coilpacks fail. But in the A4 I understand that fuel pumps can go, and destroy the engine.
    What things should I check over thoroughly? I don't want to buy a lemon.
    Also is the standard Audi Satellite Navigation any good? It's the one without the screen (ie not SatNav Plus)?
    Cheers fella's (there's no women on this forum are there? )
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    check the cambelt has been replaced, i think it should be done at 80k (it was on mine)
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    pav-g's Avatar
    Jan 2007
    Bradford
    728
    Check suspension, should have sports set up any noises when your going over bumps - the ball joints, shocks will need replacing.. good luck.
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Thanks for the tips fella's.
    The seller says the cambelt was replaced at 85k, and the cars just done 94k. It's a bloody good deal, the owner is willing to let it go for 5000, which seems too good to be true, but I won the bid on ebay and he said he will honour it. Just a bit risky to buy a car without having seen it though!
