Results 1 to 14 of 14
    Jan 2007
    12
    Can you change a Concert to RNS-E?
    Sorry if this has been covered before, but can you retro fit the RNS-E if you only have the single DIN HU? I've got a 2003 Quattro sport avant and fancy the satnav& tv but not sure what needs changing or if it is even possible? Any advice welcome.
    '03 A4 1.8T Avant Quattro Sport
    '04 A8 3.0 TDI Quattro
    '08 A8 3.0 TDI Quattro Sport
    Niknak's Avatar
    Oct 2006
    manchester
    864
    Hi yeah but it's not cheep, check out this thread.
    Sat Nav installation service
    Sinny71's Avatar
    S55 LKS
    Jan 2007
    North East
    777
    Check out this for instructions on changing from a single din to double din to accomodate the RNS-E.
    http://www.harddrive.plus.com/Docume...%20in%20A4.pdf
    2004 1.9TDi A4 Avant Sport, GmbH bodykit, DPM Remap, Fishscale Alu trim, RNS-E
    Jan 2007
    12
    Cheers for that. Looks a bit duanting! Think I might leave it to the experts. Does anyone know of any one in the south of England that does these installs?
    Sinny71's Avatar
    S55 LKS
    Jan 2007
    North East
    777
    It does look to be a fair bit of work. But when an RNS-E install could cost over £1000 it makes it look like worth a try.
    Adding the TV tuner is a big job too and I was quoted close to another £1000 for that.
    Mcgough's Avatar
    Oct 2004
    Newcastle
    820
    simple job ive done it 3 times!!
    jut takes a few hours! and wiring is simple. let me know if you need any more advice
    2010 A4 Avant B8 S-Line Executive 143ps 2.0 Tdi Ice Silver
    Extras - 5 spoke 18's, Comfort Pack, Electric Seats, Start-Stop, alcantara/leather, Silver Stitching, Factory Tints all round, Cruise control, symphony 6 disc changer, mobile phone prep low
    Previously Owned 2002 Red A4 Avant Quattro Tdi 130 , 2004 Red A4 Avant Quattro Tdi 130
    Dec 2006
    35
    Does any reprogramming need to be done, also i'm sure i've read you need to tri bits down to fit, i also fancy doing this but don't want to make a balls of it.
    Mine would be going in a cabriolet, is the aerial already i the boot?
    PAUL.P's Avatar
    Jan 2007
    Seaham, co durham
    26
    HI, GRAIG MAY DO IT FOR YOU, IVE JUST HAD VERY GOOD QUOTE OF 1149, FOR THE SAME CONVERSION AS YOU, AND HE GIVES A 12 MONTH WARANTY, ILL BE USEING HIM AS SOON AS I GET TIME TO ARRANGE IT A LOT OF PEOPLE SEEM TO USE HIM.
    Dec 2006
    35
    Quote Originally Posted by PAUL.P
    I appreciate the above, but you can pick a used RNSE up for around 400, add another couple of hundred (?) for the other bits & bobs & there's quite a saving if it's not too difficult a job to do yourself?
    Mcgough's Avatar
    Oct 2004
    Newcastle
    820
    id do it yourself, it may new vag com if you got bose, phone prep etc but if it come from similar can then thas fine, mine was pre coded for my 19's also!
    but if you can put up with the navi getting last for a few mins when you go out of signal then you dont need it coded!
    Sinny71's Avatar
    S55 LKS
    Jan 2007
    North East
    777
    I've just got an RNS-E from fleabay for £390 plus postage and will have to tackle this job myself. Most things I should be able to sort out myself.
    One question though, can the current Climate control unit be modified to fit lower down? Or will I need to get hold of one specifically for the double din head units or RNS-E.
    Niknak's Avatar
    Oct 2006
    manchester
    864
    No you can use the old one and trim it down.
    Ian
    Sinny71's Avatar
    S55 LKS
    Jan 2007
    North East
    777
    Cheers Ian, thats the answer I was hoping for.
    Mcgough's Avatar
    Oct 2004
    Newcastle
    820
    i had a spare one but niknak now has it!!!
