WHATS GOING ON M.P.G A4 TDI NOT GTI!
vw754
vorsprung Durch Technik
U.K
Filled up to the top,from shell (86.9 pece per litre) drove nice and nomal(no heavy right foot used) did 100.3 miles,went back to shell cost me 19.00 pounds! to fill up again!
Whats going on,new temp sensor fitted fully serviced,it does take a few seconds to start,but only sometimes weather engine is hot or cold,will this make a difference? plenty of power in the car. Im sure it should of used no more than 10 pounds.
HELP! A4 TDI 130BHP AWX ENGINE 2001 (B6)
Just over 20 mpg in English then....
Doesn't sound right at all!!
Ive had the same problem using shell extra diesel as well poor mpg filled up with bp got better mpg strange i wonder whats up with shell diesel :uhm:
i thort shell was good,ill try a different pump,see if that makes a difference!
The fuel will make a slight difference, but no way will it transform a car from 20mpg to 48mpg
temp sensor is new (4 week old) on vag-com temp reading was 80'C and on gauge was 90 ,is this a problem,if so whats the cause as sensor has been replaced?
Also where is the thermostat located,is it a simple job?
