Chris NottSky Insurance
    Dec 2003
    Clarkston, Michigan USA
    247
    Performance Camshafts for the 3.0L Petrol (AVK)
    Does anyone know if there is a shop in the EU that makes performance CAMS for Audi's?
    -Dan from Detroit
    2002 A4 3.0 Tip/Quattro/Sport/Premium
    Quattro GmbH front and lower door flares | Powerchip ECU Chip
    Borla Cat-back exhaust | Hyperflow Intake | B7 RS4 Dead Pedal with RS6 Gas/Brake Pedal
    Bi-Xenon Headlamps | S4 Sideview Mirrors | Phatnoise in Glovebox
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    try www.pipercams.co.uk or www.kentcams.com they do one off jobs, and if you send them your original camshafts they will reprofile the base circle to make the nose circle lift higher. Thats an option....
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Jan 2007
    Laaaaandan
    263
    How much do you reckon a new set, or a reprofiled set, of cams would cost? I presume a re-map should be done afterward too to optimise the new flow?
