JMB RetrofitsEM Tuning
    Jul 2006
    80
    What parts do I need for a service
    Im going to buy the parts for the service and have an independent fit them,what do I need ?
    Cars an A4 Avant tdi sport on 46,0000 miles
    I'm also going to get the cambelt changed,do I need to get a new water pump fitted at the same time ? Anything else I should get fitted or changed when doing the cambelt/service ?
    John
    Jul 2006
    80
    bump
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,973
    get rest of the belts changed
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Cambelt kit (from GSF comprises belt, idler pulley and tensioner)
    Waterpump
    Auxilliary drive belt
    G12 coolant (2 bottles)
    Oil air fuel and pollen filter
    Engine oil
    Sump plug (just in case)
    Wiper blades
    Brake linings (if they are worn out)
    You should also think about changing the brake fluid.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Jul 2006
    80
    Thumbs up
    Thanks ,very usefull.I'll get onto to it !
    Oct 2006
    Manchester
    724
    If you are doing the water pump , and going to GSF make sure you get the metal impella`d water pump
    They are about the same price as the plastic ones and will last longer
    If you go to a dealer , they only supply plastic
    Sarah
